1968 Hemi Dodge Dart rear wheel well template help.... #1666248
09/01/14 04:08 PM
09/01/14 04:08 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
I recently obtained Super Stock rear wheel well templates from Bill Reilly (Reilly Motorsports). I placed them on the car and they do not look correct in my opinion. Too much would be taken out of the front portion. I don't want to hack up these quarter panels if its not correct.
It seems like everyone has their own template. Attached are images of Reillys template and two different templates I located online.
Your opinion? Has anyone done this?
Thanks Moparts!
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666249
09/01/14 04:09 PM
09/01/14 04:09 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
2
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666250
09/01/14 04:10 PM
09/01/14 04:10 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
3
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666251
09/01/14 04:11 PM
09/01/14 04:11 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666252
09/01/14 04:11 PM
09/01/14 04:11 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666253
09/01/14 04:12 PM
09/01/14 04:12 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666254
09/01/14 04:26 PM
09/01/14 04:26 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Get ahold of Steve Atwell...
He's here, in Rochester Hills I believe...
He knows LO23's...
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: RSNOMO] #1666255
09/01/14 04:30 PM
09/01/14 04:30 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
He knows LO23's...
What is his username?
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666256
09/01/14 04:32 PM
09/01/14 04:32 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I do not know if he is a member here...
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: RSNOMO] #1666257
09/01/14 05:11 PM
09/01/14 05:11 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I found out years ago that if you take a passenger side front fender and set it up against the drivers side quarter the outline is perfect. Here is a pic of my original Hemi Dart for comparison...
JB Rhinehart, Realist
A-Body's RULE!
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Rhinodart] #1666258
09/01/14 05:20 PM
09/01/14 05:20 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
What are you lining it up to?
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Rhinodart] #1666259
09/01/14 05:57 PM
09/01/14 05:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Exactly, the front fender opening is the template for the rear, but that's your starting point for a Hurst rendition, IMHO your better off installing the tire you plan on running, mock up your own template opening based on the front fender opening, then measure twice, cut once, rather than trim, trim, trim, then mount the tire of choice, and trim again
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: DAYCLONA] #1666260
09/01/14 06:21 PM
09/01/14 06:21 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
Ok but how are you lining it up to cut it??? Can anyone confirm this to be true? I just don't want the car to be butchered, I am trying to build a replica as close as possible.
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666261
09/01/14 06:28 PM
09/01/14 06:28 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is the tough part, nobody seems to know exactly how it was done originally. I know several people that have used the O'reilly template and it looked fine. I have seen other templates for sale but do not know for sure where they come from. If you look at a factory car, it is butchered. If you are trying to get a factory looking car it will look like shinola. My car has been butchered through the years worse than the factory did it. I believe all the templates have been drawn off of factory cars, so that is why they are all a little different.
A-Body's RULE!
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Rhinodart] #1666262
09/01/14 06:36 PM
09/01/14 06:36 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
The issue with the Reilly template is that it requires you to remove to much from the front. If I were to follow the template, I would have to re-weld part of it back on because the template goes past the inner wheel well.
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666263
09/01/14 07:15 PM
09/01/14 07:15 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
The front should match right up to the back of the rocker panel. Don't forget to leave some metal for bending a lip around.
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: Chryco69] #1666264
09/01/14 07:29 PM
09/01/14 07:29 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
just my opinion: part of the issue is when the cars were converted to pro stock and modified where rules were less stringent then super stock. being able to use narrower axles allowed bigger tires which required more metal removed and different angles on the openings. also while building my tribute car i talked to john balow of mcr and he said that because different shifts worked on the same car he had seen differences in the left and right profiles on the same car. bob torzzi (sp) said these were the crudest race packages chrysler ever produced and when they were picked up/delivered the were nothing like the over restified examples we see today. i will show a picture of my wheelwell only because i have been complemented many times on how the profile looks original and to maybe help the op out. be for warned i did not cut them as high as the original cars as it is not tubed and a 295/65x15 mickey was the largest tire i could fit on the car
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: 3ddart] #1666265
09/01/14 07:33 PM
09/01/14 07:33 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
here is a finished picture. also check with "troy" as he use a projecter to enlarge/project the profile of a hemi dart diecast car onto a wall to get his templet.
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: 3ddart] #1666266
09/01/14 07:54 PM
09/01/14 07:54 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
herbert's original lo23 picture from indy last friday
Re: 1968 Hemi Dodge Dart rear wheel well template help.... [Re: 3ddart] #1666267
09/01/14 08:20 PM
09/01/14 08:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The front portion that got cut on these cars was after they allowed bigger slicks in 69/70.
Here's how Troy did it on his Hemi Dart clone. It was in MCG a couple years ago if you remember it.
Helpful links with tons of info:...
https://board.moparts.org/ubbthreads/showflat.php?Number=5287809
And
https://board.moparts.org/ubbthreads/show...part=1&vc=1
And
http://www.forabodiesonly.com/mopar/showthread.php?t=153383&page=2
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
