2000 Sebring won't start after rain #1666139
09/01/14 11:18 AM
09/01/14 11:18 AM
New Jersey, USA
JeffRacerG Offline OP
New Jersey, USA
Help! My 200 Sebring has developed a problem where it will crank over but won't start. Repair shop thought it was fuel pump. About a week after $260 repair it does it again. After several episodes I have figured out it happens after rain storms. Most times, after repeated tries at cranking it if often stumbles and after pumping gas pedal will eventually start. Any ideas will be helpful. It is supposed to rain again!
Re: 2000 Sebring won't start after rain [Re: JeffRacerG] #1666140
09/01/14 11:43 AM
09/01/14 11:43 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
does the car have a distributor cap? you didn't mention the engine size..wet weather is wet cap or very bad ign wires
Re: 2000 Sebring won't start after rain [Re: JeffRacerG] #1666141
09/01/14 11:50 AM
09/01/14 11:50 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You first need to figure out if you are losing fuel or if it is losing fire. You did not say if it were a 2.5 v-6 or 4 cylinder. If it's a 2.5 I would bet its a firing issue. They commonly have distributor issues. Since it does it only after raining I would check the hood to cowl seal for leakage. The distributor lives under that area and could be getting wet causing your problem.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2000 Sebring won't start after rain [Re: 71yelladustr] #1666142
09/01/14 11:57 AM
09/01/14 11:57 AM
New Jersey, USA
New Jersey, USA
It is the 2.5 V6
Re: 2000 Sebring won't start after rain [Re: JeffRacerG] #1666143
09/01/14 01:20 PM
09/01/14 01:20 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
It's fuel injected. Pumping the gas pedal does not do a thing. Holding the pedal to the floor will do a clear flood if flooded (stops the injectors from spraying fuel)Yes, that vehicle does have a distributor cap and rotor, and wires. Not the most fun to do. To do the wires you need to pull the upper intake off. The distributor is also prone to failure. It has module, coil housed inside the distributor. pricey ignition system.
Re: 2000 Sebring won't start after rain [Re: moretoys] #1666144
09/01/14 01:40 PM
09/01/14 01:40 PM
New Jersey, USA
New Jersey, USA
Considering the fact that wet weather is involved it is starting to sound like car and wires to me. By the way, check engine light never comes on and the computer never throws a code. Thanks again for the imput.
Re: 2000 Sebring won't start after rain [Re: JeffRacerG] #1666145
09/01/14 03:11 PM
09/01/14 03:11 PM
New Jersey, USA
New Jersey, USA
So it looks like cap, rotor and wires are in order. Going to do plugs while I'm in there and think I'll need gaskets. Anybody think of anything else I should do while I'm in there?
Re: 2000 Sebring won't start after rain [Re: JeffRacerG] #1666146
09/02/14 11:54 AM
09/02/14 11:54 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
I bet wires too, my Dakota did that one day after a rain, turning it over at night with the hood up after a rain looked like a lightening show.
