The other 451, cam choice w/manifolds? #1666060
09/01/14 04:27 AM
09/01/14 04:27 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
I decided to move forward on a "beater" motor for my '68 Bee and stash the original 383. I had another '68 383 block laying around so I dropped it off at my not-so-local anymore machine shop back in the high desert. Another moparts member made me a great deal on some .030 1.320 CH Diamond pistons, I picked up some BBC 6.700 K-1 H-beam rods on clearance from Wiseco, and ordered a 3.915 B-Motor crank from 440 source. I plan to run Eddy heads so this setup will yield 451 cubes at about 10.5 compression. I want to keep a somewhat stock appearance so I plan to run the factory HP exhaust manifolds and 2.5" factory style 440 exhaust. The 383 had a Performer RPM and an 800 Edelbrock AFB so I'll be swapping that setup onto the 451. A fresh coat of turquoise paint and a 383 pie-tin will go a long way to hide the true nature of this motor.
Question is, is there a better "manifold" cam out there than the old .528 MP solid? I know Andy's "manifold" 471 ran best with that cam & this motor is really just a smaller version of his 471. That was a few years ago, has anyone actually run something that works better?
FWIW Gears are 3.73 & I plan to drop the 3000 converter to about a 2500 converter
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666061
09/01/14 10:32 AM
09/01/14 10:32 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
IMHO...that 528 cam is going to be very hard to beat in performance.It's really a good cam,I've used it in 2 engines with great results.
Nautilus Racing-
Re: The other 451, cam choice w/manifolds? [Re: Chris2581] #1666062
09/01/14 01:20 PM
09/01/14 01:20 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I like the 528 as well.
Sheldon
Re: The other 451, cam choice w/manifolds? [Re: RUNCHARGER] #1666063
09/01/14 01:56 PM
09/01/14 01:56 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
The .528 MP cam wins hands down. Any doubts, PM Andy F.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666064
09/01/14 03:45 PM
09/01/14 03:45 PM
AndyF Online content
AndyF  Online Content
Every cam guy I talked to told me that they could grind a cam which would work better than the old MP .528 grind. I tried all the cams that people sent me and none of them actually worked better.
I'm pretty sure that if I picked up the phone today and called the cam grinders everyone would tell me again that yes they do have cams that work better than an old purple shaft. Question is do they, or are they kidding themselves?
Dwayne Porter is about the only guy who I would expect to deliver a cam that works better than the MP 528.
Most cam vendors do not have much experience with exhaust manifolds so they are really lost when it comes to designing a cam for that application. They'll tell you that they can grind a cam for you but when you dyno test it and tell them the numbers then they'll come back and say "oh yeah, looks like we need to adjust some things". That is okay if you're rich and have lots of time but most guys can't afford to do that much testing.
Re: The other 451, cam choice w/manifolds? [Re: AndyF] #1666065
09/01/14 06:52 PM
09/01/14 06:52 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Thanks guys, 4-0 pretty much sums it up! Thanks for the articles Andy, its always great to have someone take the time (and $)to prove what works for real & what doesn't. Funny how these old Mopar grinds are regularly dismissed by folks as "old technology" but the numbers show they are still pretty tough to beat when compared apples to apples:
https://board.moparts.org/ubbthreads/show...rue#Post7899803
Any thoughts on where I should start out on my jetting?
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666066
09/01/14 07:37 PM
09/01/14 07:37 PM
Always start the testing with stock jets in the carb. The carb mfgs send all performance carbs out the door slightly rich so dead stock jetting is usually a safe place to start.
Re: The other 451, cam choice w/manifolds? [Re: AndyF] #1666067
09/06/14 02:22 AM
09/06/14 02:22 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Thank Andy, BTW your engine building book is great!
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666068
12/17/14 01:55 AM
12/17/14 01:55 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
After reading and re-reading Andy's "Lobeology" article and talking to Dwayne Porter a couple times, I'm contemplating going with a custom Comp grind for my 383/451 to try to improve on the MP .528 cam, maybe get a little more lift & get the lash down to the .016-.020 range. One option is to run a comp xs-282s solid on 112 centers. Another thought was to run a pair of comp 6581 MM lobes on 112 centers. The "net lift" specs with 1.6 rockers are as follows:
MP .528: 241/241 .535/.535 112 Lobe centers
Comp 6581/6581: 239/239 .557/.557 112
Comp xs282s-12: 244/252 .537/.561 112
Anyone run the XS282s with manifolds?
Do the MM lobes survive on the street? I was planning to run EDM lifters, is nitride required too?
Or am I overthinking this?
FYI-For heads I'm going to run Porter Racing prepped Stealth Heads so I can have straight plugs.
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666069
12/17/14 06:55 PM
12/17/14 06:55 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Questions / comments:
1. What did Dwayne P. suggest? And are you second-guessing him?
2. I'd be hesitant to run MM-type lobes w/o both EDM lifters AND nitriding... and I'm not so sure they'd be the right choice for an engine getting a lot of street miles. Something milder will be kinder to your valve springs, etc., over time.
Re: The other 451, cam choice w/manifolds? [Re: BradH] #1666070
12/17/14 07:00 PM
12/17/14 07:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
what about angle plugs and cast exhaust manifolds?
Re: The other 451, cam choice w/manifolds? [Re: lewtot184] #1666071
12/17/14 09:23 PM
12/17/14 09:23 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Porter prepped stealth heads, straight plugs.
Re: The other 451, cam choice w/manifolds? [Re: BradH] #1666072
12/17/14 10:19 PM
12/17/14 10:19 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
I don't consider weighing the facts as 2nd guessing. You make a good point about wear & tear. Sounds like if I want to do something like option 2, I need to talk to Dwayne about a street roller but Andy Fs testing showed that more is not always better in this case. I have no doubt that Mr Porters recommendation will perform well but it's not clear to me that the extra expense of a custom solid or roller will buy much, if any, improvement in performance .
Re: The other 451, cam choice w/manifolds? [Re: BradH] #1666073
12/17/14 11:03 PM
12/17/14 11:03 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The motor will respond nicely to faster ramps. It is just a trade off on valve train abuse and running closer to the edge. There are several profiles between the XE and MM profiles in aggressiveness, but most are recommended to have direct face oiling and nitriding.
Re: The other 451, cam choice w/manifolds? [Re: lewtot184] #1666074
12/17/14 11:07 PM
12/17/14 11:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Andy ran the angle plug ebrocks and manifolds ,there rear cylinders on both sides get close to the manifold downpipe.
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666075
12/17/14 11:10 PM
12/17/14 11:10 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
......but it's not clear to me that the extra expense of a custom solid or roller will buy much, if any, improvement in performance .
It will give improvement, and I would call it "much". "Much" is relative and subjective, however.
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666076
12/17/14 11:20 PM
12/17/14 11:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I was on the phone with Dwayne the other day going over the same stuff, I have a Solid roller that came out of Wayne Smothers 440 cube F.A.S.T. 69 A12 Bee , it went 120 something in the 1/4 with high compression. I'm finally screwing together my 383 based 451 F.A.S.T. build this winter and was originally asking about throwing that roller in a 10.0 383, he said it was too big and it wouldn't accomplish what I wanted ... 12.50 index class at the local track ... without wailing the pee out of the 383, plus slicks and headers w/no exhaust.
Dwayne has had his hand in a number of the F.A.S.T. BB wedge motors so I would go with what he says about cams ... be warned that a cam for exhaust manifolds will not work very well should you decide to swap to headers.
If you go with a Comp flat tappet get it nitrided and use the EDM lifters ... worth the money for piece of mind after I had a shelf comp go bad 6 minutes into break in ... better safe than sorry. I have/had a Comp solid that he had done for me , I for the life of me can't figure out where I put it when I pulled it out of the assembled long block when he talked me into upping the compression from 11 to 12.5 ... I still have the cam card so I can give you the grind number if you want to try that .
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666077
12/17/14 11:26 PM
12/17/14 11:26 PM
BradH Offline
BradH  Offline
Exhaust manifolds are restrictive and make cam selection even more critical IMO. Too much overlap (whether the result of tight lobe centers or fast ramps) causes excessive reversion that hurts torque.
Faster ramps are not always better, dual pattern cams are not always better, and unless your heads flow a lot at high(er) lift, the benefit of a street roller over a good solid flat tappet can be minimal.
And tell Dwayne I said "Hi" when you call him next time.
Re: The other 451, cam choice w/manifolds? [Re: BradH] #1666078
12/17/14 11:59 PM
12/17/14 11:59 PM
Central NC
gch Offline
gch  Offline
Central NC
If you want a little more lift out of the .528 then run some 1.6 rockers.Ask the experts if this will have any negative effects with the manifolds.
Re: The other 451, cam choice w/manifolds? [Re: BradH] #1666079
12/19/14 01:27 AM
12/19/14 01:27 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
I agree totally. Andy F's article clearly demonstrated that when it comes to a manifold engine, limited overlap and fast ramps are about the only things that made a real difference, and even then only a couple of the custom cams were marginally better than the .528. And the smaller Racer Brown cam was surprisingly close to the .528 with great punch at lower rpm.
Then when you look at Keith's "Fading Color" article, only 1 solid offered a substantial power increase over the MP .590 with fairly minor variations of lift/duration. This leads me to the conclusion that all of these customs might offer marginal gains ( or losses) until you hit that "sweet-spot" of lift, ramp, duration, & lobe angle where respectable gains can be had.
Problem is since every engine combo is slightly different, finding that "sweet-spot" requires either previous experience with a given combo or a wad of cash & a dyno. Obviously Dwayne, Andy (and others) have plenty of real life experience with similar setups to mine, I'm sure either of their recommendations will work well. Just trying to arrive at the best possible choice when its time to pull the trigger next month.
Thanks for everyone's help.
