Re: H-beam Rod question
[Re: 68hemiss]
#1665914
08/31/14 05:31 PM
08/31/14 05:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Loosen the cap screws and tap the screw heads while you hold the cap... on the crank just tap the screws after loosening them a couple turns ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 68hemiss]
#1665915
08/31/14 05:32 PM
08/31/14 05:32 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Since they are cap screws and not "bolt through with nuts" they should fall apart after screws are removed. ![](/ubbthreads/images/graemlins/shruggy.gif) when on crank back off bolts a bit and tap bolts to split in a soft jaw vise slight tap with plastic hammer after removing or loosening cap screws.
[Re: Dodgem]
#1665918
08/31/14 08:08 PM
08/31/14 08:08 PM
Posts: 16,932 NC
440Jim
NC
They don't. The locating dowels around the bolts keep them together even without the bolts. But they do separate fairly easy with taps from a hammer as others have said.
[Re: MR_P_BODY]
#1665919
09/01/14 12:01 AM
09/01/14 12:01 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
![](/ubbthreads/images/graemlins/iagree.gif)
But I did buy a cap splitter and rod vise too. I measure the rod ends with a dial bore gauge, so I need to torque the rod bolts in the rod vise, then after measuring the bearing size, I use the cap splitter for disasembly. If you are tring to use plastigauge, you will have to put it on the piston side of the rod bearing, not the cap side.
