Page 2 of 3 1 2 3
Re: Ok Lets Talk about Distributors [Re: Dunnuck Racing] #1665866
08/31/14 09:52 PM
08/31/14 09:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Firecore wasn`t around when I got mine so,.............do tell though about your MSD dislikes.
Re: Ok Lets Talk about Distributors [Re: Thumperdart] #1665867
08/31/14 09:58 PM
08/31/14 09:58 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have been running the same MSD distributor for over 10 years in 3 different motors and have not had any issues so far. It is locked at 35* now.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Ok Lets Talk about Distributors [Re: Thumperdart] #1665868
08/31/14 10:10 PM
08/31/14 10:10 PM
NY
challenger451ci Offline
NY
My locked Mallory Unilite works great and holds the timing solid. Been running he same one since the mid 90's.
Re: Ok Lets Talk about Distributors [Re: challenger451ci] #1665869
08/31/14 10:22 PM
08/31/14 10:22 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
MSD Pro billet that was a display model for a speed shop. Got it for $75 on eBay years ago. It had no guts so it's perfect for my crank trigger.
Steve
Photobucket sucks
Re: Ok Lets Talk about Distributors [Re: fourgearsavoy] #1665870
08/31/14 10:32 PM
08/31/14 10:32 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Fire Core billet.....Set initial and total independantly, or lock it out, very easily....Luv it.
Had one in the car for 3 years now with ZERO issues and it fits with most cylinder heads without grinding
https://www.customwiresets.com/product.php?productid=16285&cat=0&page=1&featured
Gus
After having TWO Firecore failures I went crank trigger and if I didn't go crank trigger I would have returned to stock or MSD.
Russ
Re: Ok Lets Talk about Distributors [Re: max_maniac] #1665871
08/31/14 10:46 PM
08/31/14 10:46 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
All this stuff comes out( distributors, wires, etc) that is already around, and proven, and doesn't cost any more for Mopar than it does for Chevy or Ford.
What I wish was available was heads and blocks, stuff you can't find available and is truly a need.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Ok Lets Talk about Distributors [Re: B3422W5] #1665872
08/31/14 10:51 PM
08/31/14 10:51 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Some of my MSD stuff is so old it could be in a museum on display so why change now.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ok Lets Talk about Distributors [Re: Dodgem] #1665873
09/01/14 12:28 PM
09/01/14 12:28 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Where do you caps and rotors for tach drive distributor and maybe a magnetic pickup was thinking would be nice for nostalgia look.
http://s542.photobucket.com/user/dodgeboy8/media/tachdizzy1.jpg.html?o=4
Are the caps and rotors for the aluminum tach drive distributors the same as the cast iron? If so I have some part numbers.
Bill
Re: Ok Lets Talk about Distributors [Re: VernMotor] #1665874
09/01/14 12:41 PM
09/01/14 12:41 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What is everyone running ? I am not ready for a crank trigger. Race car only. No Vac-advance. Billet.Just a simple /nice distributor. Thanks Jamie
There is no reason to NOT have a crank trigger. Even the best distributor in the world won't be accurate in a Mopar, because of the intermediate shaft. Now before all you guys start telling me your timing is "rock solid" with so and so distributor and intermediate shaft.........NO, its not, so lets not even start the debate..........LOL!!!
Monte
Re: Ok Lets Talk about Distributors [Re: Monte_Smith] #1665875
09/01/14 01:12 PM
09/01/14 01:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Even w/all of the collar tricks and machining the underside of the gear for a torrington bearing, mine still retards 2-3 degrees............A crank trigger is definately in my future.
Re: Ok Lets Talk about Distributors [Re: Thumperdart] #1665876
09/01/14 01:23 PM
09/01/14 01:23 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Yep........it can't possibly be accurate. Too many places for slop. In the pump, in the gear, where dist fits in gear and the dist itself. That's 4 places for clearance and backlash. Not to mention the inherent slop you have from crank to cam in ANY motor.
Monte
Re: Ok Lets Talk about Distributors [Re: 340Cuda] #1665877
09/01/14 03:00 PM
09/01/14 03:00 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Bill
Yes they are the same part. I use the Accel caps and rotors.
Nautilus Racing-
Re: Ok Lets Talk about Distributors [Re: Chris2581] #1665878
09/01/14 03:05 PM
09/01/14 03:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Thanks see mancini has them as you said.
Re: Ok Lets Talk about Distributors [Re: Monte_Smith] #1665879
09/01/14 03:17 PM
09/01/14 03:17 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Monte
Distributer timing is about as accurate as the valve adjustment chart. :eye The flying magnet style of ignition(crank trigger) has been around for ages on small engines like lawn mowers,etc.This is the most positive way for accurate timing since it set mechanically at a fixed spot on the crank and all the slop areas mentioned have no effect.It is firing at the preset degrees with the crank rotation and can only change if you physically move the pickup.
Re: Ok Lets Talk about Distributors [Re: B G Racing] #1665880
09/01/14 08:30 PM
09/01/14 08:30 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
So all I can seem to find is a MSD crank trigger kit. Installment paper work is not very good.
http://www.jegs.com/i/MSD+Ignition/121/8636/10002/-1
Not sure how this would work with my setup.
Re: Ok Lets Talk about Distributors [Re: VernMotor] #1665881
09/01/14 09:06 PM
09/01/14 09:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Piece of cake. Reluctor wheel goes behind the crank pulley. Space the alternator out the same amount ( I believe .250" ). Mount the pick-up on the drivers side, done.
Doug
Re: Ok Lets Talk about Distributors [Re: Dunnuck Racing] #1665882
09/02/14 02:16 AM
09/02/14 02:16 AM
In a house near you
Street Monkies Offline
In a house near you
That's what blows my mind. A ton of racers buy a more expensive distributor and lock it out anyway. So basically its a magnetic pick up and reluctor doing the work. A Firecore can do that for a lot less money, still has good bearings , etc in it.
There are a few reasons I dont use MSD ignition in my builds. But thats a different subject.
Keith
I agree with Keith the msd stuff is on the expensive side. The Summit brand is cheaper also and works just as well. Same thing goes with the Firecore. What I wan't to know is how many of you guys even build racin engines everyday??? When you build racinengines everyday you get pretty good and know what work's. I don't care if people has been doing it for 40 year's. When you do it everyday it comes with way more experience and expertise. Just my
Re: Ok Lets Talk about Distributors [Re: Street Monkies] #1665883
09/02/14 02:40 AM
09/02/14 02:40 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
just want to say i did a firecore on a my dads t/a chally over the weekend along with their stock looking firecore coil and dialed it in and all i have to say is wowwwwwwwwwwwww!!!!!never ran so smooth...drove like a efi car...and was very fast...the best
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Ok Lets Talk about Distributors [Re: Street Monkies] #1665884
09/02/14 03:59 AM
09/02/14 03:59 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Keith
The problem with Summit brand, Jegs brand, whatever off brand generic part you choose to buy, is that you never know who makes it from month to month. They simply award that contract to whoever will do it the cheapest and you can bet it is likely overseas...........Now, does it "work" as good as an MSD. The answer is MAYBE, but not likely. Just because the car runs, doesn't mean it works as good. When it comes to electronic stuff an oscilloscope is your friend to determine how WELL something works............The "flying magnet" part, the wheel, no big deal. The sensor, much bigger deal. Needs to be quality, so I will stick with MSD for a few bucks more
Monte
Re: Ok Lets Talk about Distributors [Re: Monte_Smith] #1665885
09/02/14 08:54 AM
09/02/14 08:54 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Just to mention that for most application a distributer is fine for most all street and race applications and has and will work but if you want to build a all out high end drag race engine and have the best and most accurate timing go crank trigger.It is so simple to set up even a cave man can do it and with todays control modules you can have control over all your timing and RPM phases.For those who want to stay with a distributer set up we recommend Firecore as the best bang for your buck,MSD is good also but more costly.With Firecore you can get replacement parts at most any auto store.
Page 2 of 3 1 2 3
