Re: NOS E-Body Trunk Extension ?
[Re: ScottSmith_Harms]
#1665420
08/30/14 10:30 PM
08/30/14 10:30 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I bought one that had Challenger written on it from the factory and never looked at the part number till a couple of weeks later and it ended up being a Cuda one. I believe mine is the driver side.
1971 HEMI E BODY REGISTRY
#1665421
08/30/14 10:45 PM
08/30/14 10:45 PM
Posts: 1,101 Ont, Canada
moparo
Ont, Canada
Just want to suggest that the distance between the valance mounting holes looks small. Challenger having a shorter valance they could be different. I can check to makes sure if you need.
performancecarrestorations.com
[Re: moparo]
#1665422
08/30/14 10:49 PM
08/30/14 10:49 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Sort of the same scenario here (long time ago mis-I.D.), the duct tape glue line you see on mine was the remnants of the tape stuck to it with "Challenger" written on it. I got it with some other parts so I didn't really care either way, but now I'm moving it so I wanted to be sure that I had it I.D'd correctly.
#1665427
08/31/14 06:13 PM
08/31/14 06:13 PM
Posts: 2,309 South, FL
cudaized
South, FL
The drain hole opening location looks like the easy give away, it's a Cuda.
Sorry to chime in so late....
