Torque Converter Finish #1665341
08/29/14 11:48 PM
08/29/14 11:48 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
So what finish is suppose to be on a torque converter in 1970?
Re: Torque Converter Finish [Re: AAR#2] #1665342
08/30/14 01:23 AM
08/30/14 01:23 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
They were installed on the engine before it was painted so it should have some overspray. I'm not sure what finish they had prior to that. Bare metal?
Re: Torque Converter Finish [Re: burdar] #1665343
08/30/14 02:24 AM
08/30/14 02:24 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I was pretty sure installed on engine prior to paint too, so was it just dusted, as in true overspray or did the exposed face (facing AFT) get painted ?
Anyone happen to have any photo's of a good example?
Re: Torque Converter Finish [Re: AAR#2] #1665344
08/30/14 04:21 AM
08/30/14 04:21 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here's the back of KSJ's 66K mile 69 Swinger 340 auto. SPD A04 (October 4, 1968) Los Angeles plant built. Troy fixed this up a couple years ago.
Owned by fellow clubmembers since 1993-ish. Bought from original owner.
Seems that the crank, flexplate, and torque converter were together when installed in the block???
Re: Torque Converter Finish [Re: autoxcuda] #1665345
08/30/14 10:40 AM
08/30/14 10:40 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
About what I expected for the forward face if mounted to the block during paint.
Would you happen to have a pic of the other side that would have been exposed?
Any explanation for the orange paint marks? Inspection of sorts?
Re: Torque Converter Finish [Re: AAR#2] #1665346
09/01/14 08:02 PM
09/01/14 08:02 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Here are front and back pictures of my factory torque converter off my 1970 340. Hope this can be of help to you.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Torque Converter Finish [Re: FJR doc] #1665347
09/01/14 08:03 PM
09/01/14 08:03 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
#2
Kevin
Re: Torque Converter Finish [Re: FJR doc] #1665348
09/01/14 08:04 PM
09/01/14 08:04 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
#3
Kevin
Re: Torque Converter Finish [Re: FJR doc] #1665349
09/02/14 10:28 AM
09/02/14 10:28 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks for taking the time to post, the pics are great, and I'm happy to see almost a twin to the way mine was done.
