Looking For a Good book On Gen 3
#1665159
08/29/14 01:49 PM
08/29/14 01:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm looking for a good book or 2 on the gen 3 engines with all the specs and performance info and what parts inter change on what and good info on the oiling thanks
Re: Looking For a Good book On Gen 3
[Re: MR_P_BODY]
#1665161
08/29/14 02:47 PM
08/29/14 02:47 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
This is handy. No real performance info though.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: 340Cuda]
#1665163
08/29/14 08:36 PM
08/29/14 08:36 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
There really isn't one Mike, torque specs are readily available and my ARP main studs and head bolts came with their own. 08 and earlier 5.7 and 6.1 stuff interchanges except the bolt pattern on the reluctor wheels. If you use Eagle or Apache heads you have to use their rockers, pushrods and valve covers because I THINK the stands are taller. I'm using a 4.05" crank in a 6.1 block and found out I had to grind for rod bolt clearance under #8 only AFTER I had the block prepped and cam bearings installed, so now I get to tank it, paint it and get cam bearings installed AGAIN. I'll take a pic when I get a chance.
Mopar to the bone!!!
[Re: 72Swinger]
#1665164
08/29/14 09:03 PM
08/29/14 09:03 PM
MR_P_BODY
Yeah, been trying to google books on the gen 3 with nothing popping up.. you would think there would be based on the years its been out there... are you using the piston oiliers... if I were to use a 6.1 crank in a 05 5.7 I assume I have to use the 6.1 ring.. and yes I'm thinking about the Apache heads.. thanks for the info
[Re: MR_P_BODY]
#1665165
08/29/14 09:17 PM
08/29/14 09:17 PM
72Swinger
Nebraska
Yes I am retaining the oil jets after some mods to them and the pistons.
[Re: 72Swinger]
#1665167
08/29/14 09:33 PM
08/29/14 09:33 PM
MR_P_BODY
What do you figure you can bore these engines out and still be strong... I'm gonna turbo this with either a single or a twin.. gotta look at what I can package.. plus are the cams ground by most companies
[Re: MR_P_BODY]
#1665168
08/29/14 11:51 PM
08/29/14 11:51 PM
72Swinger
Nebraska
I'm kinda from the train of thought "bore only as needed" although I have not seen a split cylinder wall. You can get good pistons in .010 over increments and my block got clean with a .010 over at 4.065. I havent seen anyone go past .030-.035 over without sleeves though either.
[Re: 72Swinger]
#1665169
08/30/14 12:15 AM
08/30/14 12:15 AM
MR_P_BODY
I'm looking at a 05 5.7 thats a running engine so I would think .010 will clean it up... so there isnt any problem with running a 6.1 crank in a 5.7 and using the 6.1 wheel... how about rods.. I will want something better than a powered rod.. what length would that end up being thanks for the help
[Re: MR_P_BODY]
#1665171
08/30/14 12:26 AM
08/30/14 12:26 AM
Dave_S
I have a 6.1 crank in a 5.7 block. You must use the tone wheel that came with the crank. A 6.1 tone wheel wont fit a 5.7 crank.
[Re: Dave_S]
#1665172
08/30/14 12:36 AM
08/30/14 12:36 AM
MR_P_BODY
That part I read... being that they dont fit one another.. but it all clears everything .. correct.. what rods did you use
[Re: MR_P_BODY]
#1665173
08/30/14 12:42 AM
08/30/14 12:42 AM
72Swinger
Nebraska
5.7 and 6.1 are same stroke, so you would gain a forged crank using the 6.1 and its wheel. The rod lengths are the same as well. You can get rods in stock length, 6.242 IIRC, from a few different vendors like Molnar,K1 and Callies. Pay close attention because 99% of them use a .927 SBC pin instead of the stock .984. You can also get them in Chevy journal sizes like 2.0" which is what is going in mine,im not 100% sure but I think stock is 2.10 or 2.125. You can price a few things from these guys http://www.flatlanderracing.com/
[Re: 72Swinger]
#1665174
08/30/14 01:04 AM
08/30/14 01:04 AM
MR_P_BODY
Thanks... wasnt sure if they were the same stroke
[Re: MR_P_BODY]
#1665175
08/30/14 10:28 AM
08/30/14 10:28 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Best sources out there: http://www.lxforums.com/board/showthread.php/24486-New-Service-Manual-Download-Linkhttp://www.enginebuildermag.com/wp-content/uploads/46568ChryslerHe_00000019776.pdfIf I need a Hemi specific engine question answered, I search on google including the text: site:lxforums.com Whether it is pushrod length, lifter travel, which tone wheel for aftermarket cranks, etc, I'm able to find the answer. Also- useful swap info can be found on the FABO 3G Hemi swap forum. You have to dig a little though. I had a 6.1 crank in a 5.7. Use the 6.1 tone wheel. It fits plenty fine. I'm a fan of K1 rods and Wiseco pistons for the new gen Hemi's. That's what I run. IMO, you should copy Matt's turbo build for the long block. 6.1 crank, k1 rods, Wiseco pistons, eagle heads, and upgraded spring. Use main studs (get block honed for them), and you'll be GTG for ~1,000 hp or so. FYI- stock head gaskets and stock head bolts have held up to ~20 psi on Hemi-C's YSI Magnum (a few build revisions ago). Much beyond 18-20 psi things can get expensive. 5.7 cylinder walls are thicker than 6.1's. You need to measure wall thickness if you want to go more than .020 on a 6.1, and I would suggest it for more than .030 (or so) on a 5.7. I've read somewhere a 5.7 bore can be bored like .080 before reaching the same cylinder wall thickness that comes on a 6.1. Some 6.1's can't take a bore , but I also know of a couple running a 4.100 (.045 over) bore.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: MR_P_BODY]
#1665177
08/30/14 11:14 AM
08/30/14 11:14 AM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
The 5.7 (non-VVT) blocks are a good choice. Just be sure to sonic test the bores. It took me 3 blocks to find one I felt was acceptable. There was obviously quite a bit core shift when these were made. As far as boost limits on stock head bolts and gaskets - we've taken a completely stock 6.1 engine to 28psi with no sign of head lifting. This doesn't mean I'd build a purpose built engine with this configuration - just relaying the strength of the stock setup. Go with head studs and Cometics. Modern Mopar Forum is a good place for full tilt Gen III Hemi info if you don't mind the drama. Here's a link to a thread on pushing a stock 6.1 to the limits: http://modernmoparforum.com/topic/12184-...e-photos-added/
[Re: MR_P_BODY]
#1665178
08/30/14 11:14 AM
08/30/14 11:14 AM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Not a book but you might want to consider getting the pushrod alignment tool since you can't really assemble the valvetrain correctly without it. We had them at the dealer, it was a Miller tool.
'71 Duster '17 Ram 1500
[Re: MR_P_BODY]
#1665180
08/30/14 01:45 PM
08/30/14 01:45 PM
1badx
Portersville, Pa
What I'm looking to build wont use much boost.. maybe 15-20 psi max.. it'll be a stand alone injected with either a single or twins with intercoolers.. just a street/strip ride that will only run 10.0 in a 2900# Rampage... I'll most likely get the engine in and running then mock up for the turbo/s and see what will fit... nothing fancy for power
You wont need boost to run 10.0 at that weight with a Gen III Hemi. We have a customer with a 3700 pound 4 door, 7L running 10.30 NA. There's several others out there doing the same or close and many daily drivers weighing 4200#'s running high 10's NA.
[Re: 1badx]
#1665181
08/30/14 02:46 PM
08/30/14 02:46 PM
MR_P_BODY
Yeah I know but when I can get to a few tracks I want to turn it up to see hat it can run.. mainly the turbo will be for looks and some fun... plus I want to run on 87 octane for the street and some 93 at the track... it wont run much boost.. MOST of the time
[Re: MR_P_BODY]
#1665184
09/01/14 04:55 PM
09/01/14 04:55 PM
72Swinger
Nebraska
Yes it is. Its just an oil tunnel that merges the rear oil drainback at the rear of #8 to the drainback between #6 and #8. Even if you went through, it would just drainback at the breach instead of through the 6-8 drainback.
[Re: 72Swinger]
#1665185
09/01/14 04:58 PM
09/01/14 04:58 PM
MR_P_BODY
thanks
