516 heads #1664991
08/28/14 10:31 PM
08/28/14 10:31 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
all i done was cleaned up the bowl area and gasket matched the heads,also i opened up the exhaust some,can i expect much as far as flow out of em?i am gonna stick a 1.74 exhaust valve in and have hardened seats istalled.any advice?im poor as hell(lol)so thats why i am doing all this work,haha
Re: 516 heads [Re: bigblock4x4] #1664992
08/28/14 10:34 PM
08/28/14 10:34 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
There great for building more compresion, they are good on a mild to warm 383, like my buddy has that runs low 12's. I couldn't give a set away.
Re: 516 heads [Re: ademon] #1664993
08/29/14 12:11 AM
08/29/14 12:11 AM
Norfolk County , Ontario
WORKER_BEE Offline
WORKER_BEE  Offline
516's can be made to work, but if you are not getting a 0.040" quench area, you may increase pre-ignition. Better off using a set of 452's as they already have 1.74 exhaust valves and hardened seats.
Re: 516 heads [Re: WORKER_BEE] #1664994
08/29/14 09:54 AM
08/29/14 09:54 AM
pana illinois
pana illinois
they are going on a stock 440,the pistons are down .120,im just trying to get some compression,the engine has a summit rv cam,think it was like .460ish lift and like 212@.050,the cam was a freebee,has a iron intake with a 750 holley and a set of headers.the ol truck went 9.41 in the 1/8.it's in a 68 sb truck,i have 2.76 gears and a 340 convertor
Re: 516 heads [Re: bigblock4x4] #1664995
08/29/14 10:44 AM
08/29/14 10:44 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
See if you can find some stock early 440 pistons and rods to swing in if you really want to up the compression, I just sold a set an hour ago.
With that cam you won't be losing much with those heads, sounds like a good combo other than the gears. Headers will do much more than any kind of head swap to a later set of heads.
I had a road test of a '65 426 Street Wedge car that ran 15s with the lo po cam, log manifolds, 516 heads, and small AFB. Headers, 3.91s, and a recurved distributor had it in the high 13s. Just step up the gear when you can.
Re: 516 heads [Re: GTX MATT] #1664996
08/29/14 10:57 AM
08/29/14 10:57 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Admiration For Multiple Carburetor Vehicles...
Re: 516 heads [Re: Stewpar] #1664997
08/29/14 01:28 PM
08/29/14 01:28 PM
pana illinois
pana illinois
i forgot too mention that the distributor has been recurved,im looking for a sure grip and then on too the gears,them dang suregrips are tough too come across reasonably priced,lol
Re: 516 heads [Re: bigblock4x4] #1664998
08/29/14 08:18 PM
08/29/14 08:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What Rear do you have in the truck. I have a Dana 60 Suregrip that I will let go for cheap to you or anybody else.
Re: 516 heads [Re: Sport440] #1664999
08/29/14 08:22 PM
08/29/14 08:22 PM
pana illinois
pana illinois
8 3/4,but thank you sir
