Re: Question about 540ci engine
[Re: Mojoluv]
#1664919
08/28/14 10:04 PM
08/28/14 10:04 PM
Posts: 10,001 Frostbitefalls MN (Rocky&Bullw...
gregsdart
They will work just fine. The power will come in pretty low, with lots of torque, peaking maybe 4700. Peak hp probably by 6600? SR heads are capable of 800 hp with full porting and the right build.
[Re: gregsdart]
#1664920
08/29/14 12:03 AM
08/29/14 12:03 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I believe there is a member here with either SR's or EZ's on a 572. Maybe Ron (firefighter) can chime in.
[Re: AndyF]
#1664923
08/29/14 02:07 PM
08/29/14 02:07 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
With the right cam it should be a Torque Monster.Remember torque is even more important with a heavier street car than a lighter weight race car to get it moving.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Bigcube]
#1664925
08/30/14 02:39 PM
08/30/14 02:39 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Mine has a set of the 295 cnc EZ's @ 10.7:1 in a 572ci street/strip build. Makes Killer torque (720 ftlbs)and descent horsepower (720HP) that is all in by 6000 rpm. Heads flow almost identical to yours. On a 540 the tq peak and HP peak would be higher but not by a huge amount. I'm running a .660 lift solid roller 266/272@.050 on a 110 LSA.
Ron
