Question about 540ci engine #1664918
08/28/14 09:08 PM
08/28/14 09:08 PM
Louisville, Ky.
Mojoluv Offline OP
Mojoluv  Offline OP
Louisville, Ky.
Do you guys think that a good pair of Indy SR heads will work ok on a 540ci engine? The engine is an 11:1 pump gas motor and the heads are ported fully to Max Wedge size. Flow 360 at .650. I have just heard some say not to go above 500ci with the SR heads. Thanks for the feedback....
Re: Question about 540ci engine [Re: Mojoluv] #1664919
08/28/14 10:04 PM
08/28/14 10:04 PM
gregsdart Offline
gregsdart  Offline
They will work just fine. The power will come in pretty low, with lots of torque, peaking maybe 4700. Peak hp probably by 6600? SR heads are capable of 800 hp with full porting and the right build.
Re: Question about 540ci engine [Re: gregsdart] #1664920
08/29/14 12:03 AM
08/29/14 12:03 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I believe there is a member here with either SR's or EZ's on a 572. Maybe Ron (firefighter) can chime in.
Re: Question about 540ci engine [Re: Bigcube] #1664921
08/29/14 03:35 AM
08/29/14 03:35 AM
Louisville, Ky.
Mojoluv Offline OP
Mojoluv  Offline OP
Louisville, Ky.
Thanks guys...appreciate it. I figured they would be fine on a pump gas engine and still make good power.
Re: Question about 540ci engine [Re: Mojoluv] #1664922
08/29/14 01:27 PM
08/29/14 01:27 PM
AndyF Offline
AndyF  Offline
That will work fine on a pump gas motor. Even a race motor works fine with SR heads up to the 900 hp range.
Re: Question about 540ci engine [Re: AndyF] #1664923
08/29/14 02:07 PM
08/29/14 02:07 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
With the right cam it should be a Torque Monster.Remember torque is even more important with a heavier street car than a lighter weight race car to get it moving.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Question about 540ci engine [Re: MRMOPAR622] #1664924
08/29/14 03:43 PM
08/29/14 03:43 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
They will work fine,and you can even upgrade to a 2.250 intake valve.
Re: Question about 540ci engine [Re: Bigcube] #1664925
08/30/14 02:39 PM
08/30/14 02:39 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Mine has a set of the 295 cnc EZ's @ 10.7:1 in a 572ci street/strip build. Makes Killer torque (720 ftlbs)and descent horsepower (720HP) that is all in by 6000 rpm. Heads flow almost identical to yours. On a 540 the tq peak and HP peak would be higher but not by a huge amount. I'm running a .660 lift solid roller 266/272@.050 on a 110 LSA.
Ron
