BRAKES STICKING #1664722
08/28/14 10:56 AM
08/28/14 10:56 AM
Kentuckian
sixpakx Offline OP
sixpakx  Offline OP
Kentuckian
I bought a 71 demon and the guy had changed the ft to big bolt disk, lines also, aftermarket stuff I think, he also replaced the master cylinder. Ok heres my problem the front brakes pump up and lock (full petal), so i put the car on the lift and loosen the ft bleeders and they release, a few days later they are on again with no one being in the car, is the master cyl rod to long? it,s manual brakes, anyone else have this problem?
thanks
Re: BRAKES STICKING [Re: sixpakx] #1664723
08/28/14 03:00 PM
08/28/14 03:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sounds like the rear piston in the MC isn't fully returning when the pedal is all the way up, most likely the pushrod is too long.
Re: BRAKES STICKING [Re: John_Kunkel] #1664724
08/29/14 12:23 AM
08/29/14 12:23 AM
Kentuckian
sixpakx Offline OP
sixpakx  Offline OP
Kentuckian
was thinking the same, thanks for your answer
Re: BRAKES STICKING [Re: sixpakx] #1664725
08/29/14 02:52 AM
08/29/14 02:52 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Is it a disc master?
Re: BRAKES STICKING [Re: nomore65BelvJim] #1664726
08/29/14 03:25 PM
08/29/14 03:25 PM
Kentuckian
sixpakx Offline OP
sixpakx  Offline OP
Kentuckian
that I,m not sure of, all this was done several yrs ago, but the car hasn,t been driven (wonder why?)
Re: BRAKES STICKING [Re: sixpakx] #1664727
08/29/14 04:04 PM
08/29/14 04:04 PM
Stock type disc/drum master will have 2 different size fluid reservoirs. Drum/drum will be the same size.
Stock style disc/drum:
Re: BRAKES STICKING [Re: nomore65BelvJim] #1664728
08/29/14 04:42 PM
08/29/14 04:42 PM
Kentuckian
sixpakx Offline OP
sixpakx  Offline OP
Kentuckian
ok, thanks and it is a disc type master cylinder
