Re: door lock cylinders and keys
[Re: geol]
#1664706
08/28/14 11:42 AM
08/28/14 11:42 AM
RapidRobert
Ebay (likely), www.classicindustries.com (maybe). I'm thinking these are the ones with the big round chrome face? (65/66 was the changeover year to the later small face ones but the innards still interchange). With a new cyl you can take it to a locksmith and match your ign key to it or if you have spares with the removeable rectangular chrome covers you can mix and match tumblers/spacers till any key will fit. The tabs on the chrome covers are brittle so bend them carefully just enough to get the cover off. You get the total height just right on all holes so the cyl will turn and even if you are short on parts and you leave several holes empty not to worry as no one picks locks anymore (exc in the movies)
[Re: twodoorpost]
#1664710
08/28/14 01:11 PM
08/28/14 01:11 PM
RapidRobert
The ones in the pic (as stated) are the early ones with the peened cover which needs a locksmith to open em up to rekey. The later ones have the much smaller round non tapered chrome outside face plate and have the removeable chrome rectangular tumbler cover. EDIT The hole in the door sheetmetal is different between the two groups & cyls wont interchange (likely larger on the early ones)
[Re: magic1]
#1664713
01/21/15 09:06 PM
01/21/15 09:06 PM
Posts: 4,848 Memphis
HemiRick
Memphis
any luck finding these, I need one....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
