EFI Gurus 36-1 or 60-2 timing wheel better?
#1664612
08/28/14 12:35 AM
08/28/14 12:35 AM
Posts: 22,696 Bitopia
jcc
Bitopia
I believe Electromotive EFI decades proclaimed the advantages of the 60-2 wheel to their system, in that it was a more "continuous" measurement of the crank location. It seems today at very high rpms's, higher then I am considering the 60-2 might be data overload for the ECU. Megasquirt 3 Pro offers a choice in set-up for the two and other options. Does anyone know if the Megasquirt for instance measures and utilizes all 58 teeth in ECU timing calculations, making a 60-2 tooth wheel more precise and therefore a better choice? I will contact Mega and others, but want to do my homework first.
Re: EFI Gurus 36-1 or 60-2 timing wheel better?
[Re: jcc]
#1664613
08/28/14 01:52 AM
08/28/14 01:52 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
The 60 tooth has resolution to 6 degrees vs 10 for the 36 tooth. MS does account for every tooth, and according to this page both have been bench tested to 18,000 RPM. This was good for the MS2, so I'm sure MS3 can do that with no sweat. Probably no real advantage unless you require ultra precise timing.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1664614
08/28/14 04:13 AM
08/28/14 04:13 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Maybe there is a bosch white paper (since they invented all this stuff anyway) out there someplace that explains the reasoning for the 60-2. Seems either option will work well. I used a 36-1 on mine just because you can get ford 4.6L parts in every parts store or wrecking yard in the U.S. for next to nothing. I'll look and see if I can find the right bosch training manual at work tomorrow. I don't remember what system the 60-2 was introduced on.
[Re: Monte_Smith]
#1664617
08/28/14 11:47 PM
08/28/14 11:47 PM
jcc
Bitopia
We started with a 60-2 wheel on our stuff and now use 4x flying magnet MSD wheels with a hall effect pickup.............no difference whatsoever.
Monte
My thinking is, and I way out of my league here, is often timing is talked about in one degree increments as being significant, so if a 60 tooth wheel has a resolution of 6 degrees per tooth, my original question centers around, are the ECU simply counting teeth until the -1 tooth, or are they timing the speed for ea tooth? Because it seems to me a crank really does not move at a constant rotation speed, as each cyl fires and delivers power very peaky maybe for only 30 degrees with only a max of maybe 90 degrees rotation ( and obviously the first 10? and last degrees has little benefit for added power input to the crank)
This is now all theoretical for me, as I have a 60 tooth wheel on the shelf that needs machining for mounting which i started today vs buying a machined 36 wheel.
[Re: jcc]
#1664621
08/29/14 08:13 PM
08/29/14 08:13 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
The OEMs went to high resolution crank wheels for OBD2 misfire detection....as Monte said- we don't need it.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: Mopar_Rich]
#1664622
08/29/14 10:29 PM
08/29/14 10:29 PM
jcc
Bitopia
I understand your point, but am still puzzled, then did the "old" ECU's take over 90Deg to calc the new accelerated rpm, no matter the tooth count? And the new ECU's cannot now account for any new acceleration with 4 magnets for at least 90 deg of crank rotation, no matter how fast they do the calc's, since it takes a starting pulse and the next timing pulse for an rpm calc, at the minimum, which on a 4 magnet wheel is 90 deg, correct? It seems odd so many companies offer much higher toothed aftermarket timing wheels in often race use, and there is no reported advantage. I guess I should be soon seeing that dead horse.
[Re: jcc]
#1664623
08/30/14 01:20 PM
08/30/14 01:20 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Yes the horse is dead With 4 pulses per rev the ECU had about from 20 to 80 degrees to calculate the timing, depending on where the reference pulse occurs. That gave the ECU (old or new) plenty of time to do the calcs, but the crankshaft is accelerating during this time so although the calculated timing was correct the crank itself has passed. With 60 pulses per rev the ECU just counts the pulses from the reference notch until it get to the one closest to the required timing (no calcs, just counting). Then it has only 6 degrees of time to compute the result. You need a faster ECU for that, but today that's ANY ECU.
[Re: Mopar_Rich]
#1664624
08/30/14 01:36 PM
08/30/14 01:36 PM
jcc
Bitopia
"(no calcs, just counting)" That's the heart of the question, Thanks.
