Water pump no pumpy.. ;( #1664593
08/28/14 12:21 AM
08/28/14 12:21 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Can't seem to get the water to circulate in the motor since I put it back in. It now has a hardblock fill to the bottom of the water pump holes. I tried jacking the front end up and pulling the last header bolt on the passenger side that goes to water and nothing. Anyone have any other tricks? I remember when had the 440 with a tall fill in it I had similar issues.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Water pump no pumpy.. ;( [Re: Eric] #1664594
08/28/14 12:36 AM
08/28/14 12:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Start warming up the engine.. I have the same issue
with SBs... cycle the pump on and off.. it should
start pumping when it gets warm... also squeeze the
lower hose a few times
Re: Water pump no pumpy.. ;( [Re: MR_P_BODY] #1664595
08/28/14 03:26 AM
08/28/14 03:26 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I changed my radiator one time and could not get it to prime for the longest time, I tried everything I could think of. My wife walked out and said try jacking the rear of the car up a little,
Knowing it would not help I stuck the jack under it and jacked it up and then turned the pump on and it picked up prime. I was almost mad
Re: Water pump no pumpy.. ;( [Re: SB412DUSTER] #1664596
08/28/14 07:49 AM
08/28/14 07:49 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I started using this tool years ago and no more priming or air pocket problems......
http://www.amazon.com/gp/aw/d/B0002SRH5G?pc_redir=1409138192&robot_redir=1
Re: Water pump no pumpy.. ;( [Re: Eric] #1664597
08/29/14 11:51 AM
08/29/14 11:51 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Eric I just did my trick yesterday.
Put your hand over the opening on the radiator, put your compressed air blower under your hand and put a little pressure with pump on.
If your rad. has an overflow tube in the neck, cover opening with hand and blow in the overflow tube.
Works every time!
Don
Re: Water pump no pumpy.. ;( [Re: Eric] #1664598
08/29/14 12:05 PM
08/29/14 12:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Eric what block do you have ?
Re: Water pump no pumpy.. ;( [Re: cudadon] #1664599
08/29/14 12:22 PM
08/29/14 12:22 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Works every time!
Don
Or, use a water hose... I did that to prime the Air to Water Intercooler I just installed on the 2000 Dak!
Re: Water pump no pumpy.. ;( [Re: TheOtherDodge] #1664600
08/29/14 01:33 PM
08/29/14 01:33 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You should have paid attention to what I told you."The Shadows Knows"
Re: Water pump no pumpy.. ;( [Re: B G Racing] #1664601
08/29/14 06:09 PM
08/29/14 06:09 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
..... While most of you know BGR is my usual go to guy. He had his race and many other things on his plate when the block sprung a leak. So drove it up to my old engine guy up in NY. Well he is more of a Chevy guy so he sleeved the block and unfortunately put a tall fill in it. Thus the water circulation issue. Motor is out and he is getting a different block for me which he will machine and assemble the motor with. Just to let you guys know my only cost will be the block....all machine work and assembly he said he will take care of. This also came with an apology for me missing the 10k's at Norwalk. I feel especially bad since he did the work for me so quickly in the first place. Needless to say feel confident in the fact that I have two stand up engine builders to work with...
Re: Water pump no pumpy.. ;( [Re: Eric] #1664602
08/29/14 06:33 PM
08/29/14 06:33 PM
tboomer Online work
tboomer  Online Work
Eric...Low deck or R/B? Changing anything else?
Re: Water pump no pumpy.. ;( [Re: tboomer] #1664603
08/29/14 06:46 PM
08/29/14 06:46 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Lowdeck...and nothing else till I go aluminum block and get some weight off this porker..
Re: Water pump no pumpy.. ;( [Re: Eric] #1664604
08/29/14 06:48 PM
08/29/14 06:48 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I tried to tell you guys that concrete is for swimming pools.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Water pump no pumpy.. ;( [Re: Eric] #1664605
08/29/14 06:58 PM
08/29/14 06:58 PM
tboomer Online work
tboomer  Online Work
Porker??? My junk is 3600# plus with the driver!! What does the arrow weigh?
Re: Water pump no pumpy.. ;( [Re: tboomer] #1664606
08/29/14 06:59 PM
08/29/14 06:59 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
2100#...
Re: Water pump no pumpy.. ;( [Re: Eric] #1664607
08/29/14 07:03 PM
08/29/14 07:03 PM
tboomer Online work
tboomer  Online Work
2100#???? Damn!! My modor would put that thing into the high 7.xx range!
Re: Water pump no pumpy.. ;( [Re: tboomer] #1664608
08/31/14 02:19 PM
08/31/14 02:19 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
you need to be careful doing a tall fill, it can block off flow at the head bolt bosses
