Water pump no pumpy.. ;(
#1664593
08/28/14 12:21 AM
08/28/14 12:21 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Can't seem to get the water to circulate in the motor since I put it back in. It now has a hardblock fill to the bottom of the water pump holes. I tried jacking the front end up and pulling the last header bolt on the passenger side that goes to water and nothing. Anyone have any other tricks? I remember when had the 440 with a tall fill in it I had similar issues.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Water pump no pumpy.. ;(
[Re: Eric]
#1664594
08/28/14 12:36 AM
08/28/14 12:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Start warming up the engine.. I have the same issue with SBs... cycle the pump on and off.. it should start pumping when it gets warm... also squeeze the lower hose a few times
[Re: Eric]
#1664597
08/29/14 11:51 AM
08/29/14 11:51 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Eric I just did my trick yesterday. Put your hand over the opening on the radiator, put your compressed air blower under your hand and put a little pressure with pump on. If your rad. has an overflow tube in the neck, cover opening with hand and blow in the overflow tube. Works every time! Don
[Re: cudadon]
#1664599
08/29/14 12:22 PM
08/29/14 12:22 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Or, use a water hose... I did that to prime the Air to Water Intercooler I just installed on the 2000 Dak!
[Re: Eric]
#1664604
08/29/14 06:48 PM
08/29/14 06:48 PM
Posts: 20,170 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I tried to tell you guys that concrete is for swimming pools.
