measuring lift at the valve #1664418
08/27/14 06:04 PM
08/27/14 06:04 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Decided to take some lift measurements at the valve ( see pic ). On the average, I am coming up about .040" short per valve as compared with the cam specs lift. Is this normal for a 59* stock small block? Solid lifter cam that visually looks good, as do the lifters. Couple of years running on the cam. All the valve train is in good shape. Running very light spring loads ( 110 - 315 ) so I don't see deflection as an issue. All measurements on all valves are within .010", so I don't have one way out of wack. . I accounted for valve clearance. Thoughts?
Fastest 300
Re: measuring lift at the valve [Re: Crizila] #1664419
08/27/14 06:17 PM
08/27/14 06:17 PM
dogdays Offline
dogdays  Offline
What you are measuring is correct. The problem is that the lifter is not pushing straight on the pushrod. This was first brought to my attention a few years ago when Rob McC was designing LA rockers for Erson, and was wondering if he should make the true ratio of their 1.6 rockers something like 1.65, in order to get the valve to open exactly 1.6 times the lobe lift. He posted the question in a Moparts forum. I remember trying to figure out why that would be and finally came up with the idea that the actual lift at the top end of the pushrod is the lobe lift times the cosine of the angle between the lifter axis and the pushrod.
R.
Re: measuring lift at the valve [Re: Crizila] #1664420
08/27/14 06:25 PM
08/27/14 06:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pretty normal... are you sure your rocker ratio is
correct.. I get a little less than .040
Re: measuring lift at the valve [Re: MR_P_BODY] #1664421
08/27/14 06:31 PM
08/27/14 06:31 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
That is the way it is for a 59* small block.
Re: measuring lift at the valve [Re: dogdays] #1664422
08/27/14 07:00 PM
08/27/14 07:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
R.
basically cosign of 11 degrees times the gross lift...minus the lash...
then you have the true rocker ratio...which is ???
Tony
70 AARCuda Vitamin C
Re: measuring lift at the valve [Re: 70AARcuda] #1664423
08/27/14 11:51 PM
08/27/14 11:51 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
R.
- 1.59. Actual rocker ratio = 1.6. Lost .007" lobe lift through the 11* angle.
Fastest 300
Re: measuring lift at the valve [Re: MR_P_BODY] #1664424
08/28/14 12:07 AM
08/28/14 12:07 AM
Canada
onig Offline
onig  Offline
Canada
Agreed with above statement.
If rocker geometry is off it will affect lift numbers, as well if your pushrod lengths are not correct.
69 Dart
Re: measuring lift at the valve [Re: Crizila] #1664425
08/28/14 12:47 AM
08/28/14 12:47 AM
Have you checked all the rockers at the valves yet? If not do that and let us know what you find for the variences on yours I've seen .030 difference at the valves on the same brand of rockers, the losss of lift followed the rocker when I swapped them around I have checked a bunch of stock type Ductile iron Hemi, wedges and LA rockers, Harland Sharps, Crane iron and extruded aluminum roller tip rockers, T&D single shafts and so on I've yet to see a perfect set that all the rockers lifted the same at the valves I do have a new set of Jesel paired shaft rockers that I haven't checked or tried to use yet I'm hoping that they are as good as all the high buck racers say they are
Re: measuring lift at the valve [Re: Cab_Burge] #1664426
08/28/14 01:37 PM
08/28/14 01:37 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Haven't checked the rockers yet, but I have less than .011" difference from lift readings on all 16 valves, and that is including any cam wear, etc, so they can't be too far off from one another. I'll check a few. Not even sure who's rockers they are as I bought them from Hughes as a package deal. RR350A 1.6 stamped on the tops.
Fastest 300
Re: measuring lift at the valve [Re: Crizila] #1664427
08/28/14 01:45 PM
08/28/14 01:45 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I loose about .025-.030" using t&d 1.6 rockers.
Re: measuring lift at the valve [Re: mopar dave] #1664428
08/29/14 02:17 PM
08/29/14 02:17 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I ended up with ~.475" lift with the .528" MP cam using 273 rockers. The .028"/.032" lash accounted for most of the loss, the rest probably in the 273 rocker ratio being less than 1.5.
Re: measuring lift at the valve [Re: mr_340] #1664429
08/29/14 02:28 PM
08/29/14 02:28 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
... and it's worse with hydraulic roller lifters - shorter pushrod = more angle. It's fairly subjective but in my experience it's .018-.022" less with 1.5s in most circumstances.
