Front spring hanger...top or bottom hole? #1664384
08/27/14 02:05 PM
08/27/14 02:05 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
I am getting ready to mount my SS spring in an E-body. Aside from the ride height, those of you who have tried their SS mounted in both top and bottom positions on the front spring hanger, what was your experience in how the car reacted?
Re: Front spring hanger...top or bottom hole? [Re: cruzin] #1664385
08/27/14 03:33 PM
08/27/14 03:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
Why not try them both on your car? No two cars are identicle
Re: Front spring hanger...top or bottom hole? [Re: Cab_Burge] #1664386
08/27/14 05:26 PM
08/27/14 05:26 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
With my car, I've learned that having the front spring segment as close to parallel with the ground works best. That means the bottom hole.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Front spring hanger...top or bottom hole? [Re: 68LAR] #1664387
08/27/14 06:08 PM
08/27/14 06:08 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
68LAR,
Thanks for the "firsthand" feedback. When you says "works best" do you mean it 60'/quarter mile quicker or the handling/ride quality or ??
Just curious, do you recall how much your pinion angle changed when you switched between the top and bottom?
Re: Front spring hanger...top or bottom hole? [Re: cruzin] #1664388
08/27/14 08:06 PM
08/27/14 08:06 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
...When you says "works best" do you mean it 60'/quarter mile quicker or the handling/ride quality or ??
60'and with that, my 1/4 mile times dropped as well.
Pinion angle changes by 1 1/2*, with my set up.
