Milodon 21000 vs. 21001 single line kits #1664264
08/27/14 12:40 AM
08/27/14 12:40 AM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Both of kits bypass the internal passages.....what's the diff? Is one much ($100) better than the other....Are they both sufficient? Asking in regards to my 528 Hemi thats a street motor.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Milodon 21000 vs. 21001 single line kits [Re: HemiRick] #1664265
08/27/14 09:22 AM
08/27/14 09:22 AM
an8sec70cuda Offline
Out of those 2 kits, I'd use 21001. It will give you better clearance w/ the line coming in the front of the motor.
One thing to be aware of is the oil filter adapter. Kit 21001 is just the plate that sandwiches b/t the stock oil pump and the block. You just need the longer oil pump driveshaft.
Kit 21000 shows the problematic oil filter adapter that a lot of people have had issues w/ blowing out the gasket, sometimes at high speed, and getting oil under the tires...not good.
Milodon now has billet pump covers that have the oil filter adapter built right into the pump cover...no gasket to blow out. They are very nice, but more expensive. part numbers 21205 and 21215.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'73 Chrysler New Yorker, 440, 727, 8.75....................FOR SALE
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: Milodon 21000 vs. 21001 single line kits [Re: an8sec70cuda] #1664266
08/27/14 10:42 AM
08/27/14 10:42 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Forget the 21000 and you couldn't give me a 21001. Those are 45 year old technology. Lets move on. They make better parts today. The 21001 makes the oil pump so long it may not fit in your car without notching the K frame. Either use one of the billet top covers or the 21815 pump.
2011 Drag Pak Challenger
Re: Milodon 21000 vs. 21001 single line kits [Re: rickseeman] #1664267
08/27/14 10:55 AM
08/27/14 10:55 AM
I use the 21815 pump w/ a factory cover. That or one of the new one piece covers are really the way to go.
CHIP
Re: Milodon 21000 vs. 21001 single line kits [Re: an8sec70cuda] #1664268
08/27/14 11:55 AM
08/27/14 11:55 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
On my engines I use the 21815 pump and the 21235 cover with top inlet the 21815 pump is 19gpm and suuitable for use from super gas to top fuel ( so says the package) I have never had an issues with this combo. I don't run a Kmember in any of my cars though, but you may need to notch the member if using one.
Re: Milodon 21000 vs. 21001 single line kits [Re: an8sec70cuda] #1664269
08/27/14 12:37 PM
08/27/14 12:37 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
My cam max HP is @ 6800 and I planned on a 7000 RPM redline, so the 21185 based dual line system is good for 8000 rpm and $800, double the price of the 7000 RPM systems.
Is there a way to use the 21185 pump in a cheaper single line system, closer to the $400 cost? $800 is just outta my budget for this upgrade.
Take care,
Rick
Re: Milodon 21000 vs. 21001 single line kits [Re: HemiRick] #1664270
08/27/14 01:43 PM
08/27/14 01:43 PM
Absolutely. You don't need a dual line system for your combo. You can use the 21815 pump w/ a factory cast iron oil pump cover. Then just connect the inlet on the pump to your oil pan. That's exactly what I have on my hemi.
Or use a stock pump and get the billet cover.
I remember seeing someone talking about the new billet covers not fitting too well on factory K frames...needs some clearancing. Can't be too bad though. I have 2 cars w/ single ext. systems.
CHIP
Re: Milodon 21000 vs. 21001 single line kits [Re: an8sec70cuda] #1664271
08/27/14 02:06 PM
08/27/14 02:06 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Those were on a Hemi, I wound up going with a line to the front of my world block to make it work. The covers kept hitting the mounts...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon 21000 vs. 21001 single line kits [Re: astjp2] #1664272
08/28/14 09:36 AM
08/28/14 09:36 AM
Yep, I remember now that it was you (astjp2) posting about that. Both my cars have wedge K members...obviously the hemi mounts get in the way.
The rear inlet cover they call the "hemi" cover...I don't see how it would work unless you have a motorplate and have completely removed the motor mount brackets from the K member.
CHIP
