Stall converter question for trans gurus #1664218
08/27/14 12:48 AM
08/27/14 12:48 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
I have a PTC Converter that is rated at appx 3400 rpm stall behind a 400hp motor.
My motor pushes it to about 3600on the brake before the tyres start to turn.
Is it possible for the converter to suddenly become "looser" up to the stall point - but still retain the existing 3600 point where if I footbrake it, the tyres start to turn?
Basically...the converter 'feels' like its working harder - like when there's a more powerful motor driving it - but there isnt.
So it just feels like its slipping more under normal driving...but stalls up to where it should.
There's no sign of burned trans fluid, no vibrations, although I think the front pump has got a little noisier.....
Thoughts?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Stall converter question for trans gurus [Re: Moparmal] #1664219
08/27/14 02:22 PM
08/27/14 02:22 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I think you're asking for a converter that slips less under normal driving but still stalls at the same rpm? If so yes, that is possible.
Re: Stall converter question for trans gurus [Re: GTX MATT] #1664220
08/27/14 09:28 PM
08/27/14 09:28 PM
Moparmal Offline OP
Moparmal  Offline OP
Sort of the opposite....can a converter start to slip more...due to some issue.....but still keep its stall poiint?
Re: Stall converter question for trans gurus [Re: Moparmal] #1664221
08/27/14 09:43 PM
08/27/14 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not usually.. if you changed something on the engine
where it makes more torque it will raise the stall point
but usually will have pretty close the same slippage..
even a timing change CAN make more torque
Re: Stall converter question for trans gurus [Re: MR_P_BODY] #1664222
08/28/14 11:05 PM
08/28/14 11:05 PM
Moparmal Offline OP
Moparmal  Offline OP
OK...thanks Mr P.
