NE 1 have the secret about car windows? #1664200
08/27/14 12:33 AM
08/27/14 12:33 AM
Staten Island, NY
RO23dave Online content OP
RO23dave  Online Content OP
Staten Island, NY
Both my charger and 300, none smoker cars, always gets a smokey haze on the inside of all the windows. I've heard it has to do with the plastics & other composites used inside the newer vehicles. How does one go about getting them clean? I've tried multiple cleanings with windex, zaino bros window cleaner, ammonia w/news paper, etc. I can never get the haze to go away completely, & it never lasts long. So whats the secret? Any help would be appreciated. Thanks Dave ss/ea #1355
Re: NE 1 have the secret about car windows? [Re: RO23dave] #1664201
08/27/14 01:26 AM
08/27/14 01:26 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Try a razor blade and finish it up with steel wool.
Used to remove overspray off windows at the body shop.
Mo' Farts
Moderated by "tbagger".
Re: NE 1 have the secret about car windows? [Re: Grizzly] #1664202
08/27/14 09:34 AM
08/27/14 09:34 AM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
Dave, are these new cars or old (60's/70's) cars?
Either way a leak in the heater core or underdash lines/connectors/fittings will cause a haze on the inside of windows, mainly on the windshield but the new cars move the air around to the side windows too.
If the windows feel "greasy" at all you could try some Dawn dish detergent? Might cut through it?
Re: NE 1 have the secret about car windows? [Re: Grizzly] #1664203
08/27/14 09:53 AM
08/27/14 09:53 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
This is a sure way to destroy your glass permanently.. Do not do this.
Re: NE 1 have the secret about car windows? [Re: floridian] #1664204
08/27/14 10:58 AM
08/27/14 10:58 AM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Diamondite Glasswork Restorer
Brand new cars are prone to "Vinyl Fog", that's where you get a nasty film build-up of all the icky substances used to make the high plastic content of modern cars out-gassing inside the car and while the film is probably on all surfaces you see it on the window.
One tip for getting windows clean is switch to a clean, dry microfiber after making the initial wipe to remove the film and glass cleaner. If you continue using the same cloth your removed the film and glass cleaner with then the chance that you will simply transfer this gunk back onto the window is always a possibility.
Switched to the dark side...
Re: NE 1 have the secret about car windows? [Re: RO23dave] #1664205
08/27/14 11:29 AM
08/27/14 11:29 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
try to find a product "nothin's better" works great on cleaning glass. I go over the window first with "Sprayway" glass cleaner (spray on rag and clean glass I don't like to get it on plastic rubber or paint). Then use the other product.
Re: NE 1 have the secret about car windows? [Re: floridian] #1664206
08/27/14 12:48 PM
08/27/14 12:48 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Sure way, I don't think so... A razor blade and the right steel wool won't hurt the glass as at all.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: NE 1 have the secret about car windows? [Re: Silver70] #1664207
08/27/14 02:15 PM
08/27/14 02:15 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Obviously, you two have never tried it or worked in a body shop.
Steel wool works on chrome too.
OP, if you like, just Google it first, you'll see.
Mo' Farts
Re: NE 1 have the secret about car windows? [Re: Grizzly] #1664208
08/27/14 02:37 PM
08/27/14 02:37 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Used razor blades all the time without damaging glass, I guess some of you guys never painted house windows or did paint touch up on cars.
Never, ever use scotch-brite.
(steel wool have no opinion, I have used it on chrome and stainless for polishing with great success.)
I caught a new recon guy using green scotch-brite to remove shoe polish off a windshield and it had to be replaced. dunderhead.
"I think its got a hemi"
Re: NE 1 have the secret about car windows? [Re: gdonovan] #1664209
08/27/14 02:54 PM
08/27/14 02:54 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
re: steel wool on the hardness scale it is softer than glass. Some alloys can be harder. I'd pass using steel wool on old irreplaceable auto glass, but on a newer car 0000 steelwool (softer alloy) or even any grade of brass wool can be used. The problem is if there is other contaminates on the glass (concrete at new home construction i.e. patio doors) get scratched all the time not by the steel wool, but the aggregate in the concrete being cleaned off. A razor blade is the preferred method there.
The o.p. having a contaminate on the glass does not really need a harsh method. CLean, then the product I mentioned (iirc it's ground sea shells - calcium) is softer than glass and will clean it fine.
Re: NE 1 have the secret about car windows? [Re: Grizzly] #1664210
08/27/14 04:30 PM
08/27/14 04:30 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Gosh you are correct, I have never worked in a body shop before.. Worked in the glass business for over 35 years though.. AND replaced alot of glass at body shops that did this.....
I have been the rep on a BRAND NEW home complaint where the painter did this to remove overspray. Told us we ( my company) had sent "faulty glass" ( the not my fault syndrome)
. Needed to replace EVERY PIECE OF GLASS IN THE BRAND NEW WINDOWS IN THE BRAND NEW HOUSE due to the use of steel wool....
Sure wish a "body man" had been there to straighten me out...
But I must be full of it cause I don't work in a body shop..LOL
Re: NE 1 have the secret about car windows? [Re: it's Bob] #1664211
08/27/14 07:20 PM
08/27/14 07:20 PM
Staten Island, NY
Staten Island, NY
These are new cars, 2011 300C & 2013 Charger R/T. Dave ss/ea #1355
Re: NE 1 have the secret about car windows? [Re: RO23dave] #1664212
08/27/14 09:44 PM
08/27/14 09:44 PM
5thAve Offline
5thAve  Offline
I get the same problem with both of my Fords. The dealer checked it out under warranty and I had my own shop pressure test the cooling system and neither found anything. I'm guessing it's the new car thing.
Re: NE 1 have the secret about car windows? [Re: 5thAve] #1664213
08/27/14 10:14 PM
08/27/14 10:14 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I have used both, razor blades as well as steel wool on auto glass with no issue. Not the coarse stainless steel wool; just the very fine and soft mild steel wool. The kind that rusts in even the least humidity. Too soft to scratch glass if use common sense and just use to remove the dirt, grime, film what ever. Not to try and polish it.
Re: NE 1 have the secret about car windows? [Re: RO23dave] #1664214
08/27/14 10:45 PM
08/27/14 10:45 PM
Staten Island, NY
Staten Island, NY
Thanks for the tips guys, but the windshields, at that steep angle and rear window, area's too big for a razor blade. Just seems no matter what i use, it never completely comes off, i'm always looking thru some kinda haze. front windshields the worst. Any more ideas, just keep them coming. Dave ss/ea #1355
Re: NE 1 have the secret about car windows? [Re: floridian] #1664215
08/28/14 12:33 AM
08/28/14 12:33 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
There are different grades to steel wool. You didnt state what grade the Painter used on the New House windows. I guess you didnt know, if you did you should of used that info to help state your position. But , you didnt, so you dont know do you.
Steel wool is fine on glass if the grade is fine enough. .0000 is great Great on Chrome and Stainless too. Test it out for yourself on a small spot if you want. to steel wool.
Re: NE 1 have the secret about car windows? [Re: Sport440] #1664216
08/28/14 01:00 PM
08/28/14 01:00 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Have to agree no way the painter used 0000 steel wool been using it for 40 years on glass with never a problem.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: NE 1 have the secret about car windows? [Re: RO23dave] #1664217
08/28/14 08:58 PM
08/28/14 08:58 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I've used Glass Wax for over 40 years, by far the best product ever for those tough Armor All fumes fogged up car windows.
However out of production, but at times found on EBay. I still have a couple go cans of it. Must be used according to instructions,,,but interior windows. Perfecto!
Perhaps one of these products from Amazon might do well,,,,you truly need a something beyond Windex and like products to do a good job if you are dealing with smoked up or Armor All fogged windows,,,although for light duty, Invisible Glass and excellent waffle weave microfiber cloth be pretty darn good.
Use your remaining Armor All to kill that crab grass in your lawn that Round-up can't seem to touch. Never ever use it in a car interior. Use something like 303 Protectant instead.
http://www.amazon.com/s/?ie=UTF8&key...sl_5jctkdd10c_e
Here is a link to a happy user of a Glass Wax. Worth some effort to find.
http://www.annsentitledlife.com/anns-life/best-window-cleaner-ever/
Although careful use of razor blades is ok to take paint or adhesive off a window,,,,I would never use steel wool of any kind. Do a piece of glass with it, hold it up to the sun, it's like holograph city,,,would be like washing your car with Ajax. Additionally some glass is softer than others,,,some may hold up ok, others not,,,why take the chance when there are other less aggressive means.
Just as with paint finish restoration, use the least aggressive product first.
