A/C advice needed #1664106
08/26/14 09:56 PM
08/26/14 09:56 PM
louisiana
sixty9bee Offline OP
louisiana
So I installed a new system from Classic auto air in my 69 B Body. Upon pulling a vacuum we found a leak. The leak happened to be where a screw from the firewall cover plate entered the suction line. Big props to CAA for covering my mistake under warranty. My question is do I need to replace the drier before charging the system?
Re: A/C advice needed [Re: sixty9bee] #1664107
08/26/14 10:08 PM
08/26/14 10:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not on a brand new system. Drier will only need replacing if the system is open for a long while.
Re: A/C advice needed [Re: stumpy] #1664108
08/26/14 10:46 PM
08/26/14 10:46 PM
louisiana
louisiana
What's a long while? It's been several days
Re: A/C advice needed [Re: sixty9bee] #1664109
08/26/14 11:09 PM
08/26/14 11:09 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Many driers have a sight glass. I believe the normal color is blue, if it is pinkish or white then replace it. At first I thought the drier that came in my CAA system did not have a sight glass. Upon closer inspection I found it was hidden by a black sticker/painted tape (maybe to cover the glass when painting the drier?)
Anyway, if you have a sight glass and it is blue, I would say you are ok.
I found this pic online for an example.
Re: A/C advice needed [Re: moparfan53] #1664110
08/27/14 12:21 AM
08/27/14 12:21 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't think several days will hurt anything. I was thinking weeks with a wide open system .In damp conditions.
Re: A/C advice needed [Re: stumpy] #1664111
08/27/14 12:33 AM
08/27/14 12:33 AM
usa
smos001 Offline
smos001  Offline
usa
While we are on the subject,
I am putting a perfect fit Classic AC in my 70 challenger also. The evaporator in the dash is the only component that is not being replaced.
The AC has been out of the car for several years. What do I have to do to flush the evaporator to use it with these new components? The evaporator has been open to the air for many years.
Re: A/C advice needed [Re: smos001] #1664112
08/27/14 12:43 AM
08/27/14 12:43 AM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
Before filling an A/C system you need to pull a vacuum. This serves two purposes: It removes all of the air, and it also boils all of the water out of the system (you never get it all out).
Re: A/C advice needed [Re: tahoechallenge] #1664113
08/27/14 01:14 AM
08/27/14 01:14 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
Old timer a/c guy we used at 63436 would let the vacuum pump run all night, then watch the gauges ... we didn't have a lot of a/c stuff in Vermont back then ...
It takes gasoline to interest me.
Re: A/C advice needed [Re: sixty9bee] #1664114
08/27/14 04:42 AM
08/27/14 04:42 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You just need to vacuum it longer, and make sure it holds the vacuum.
Any moisture will boil off and get sucked out of the system when you pull a vacuum on it.
At 29.02" of vacuum, water boils at 76-degrees F.
At 29.87" of vacuum, water boils at 6-degrees F.
If you vacuum the system on a warm day you should have no problem removing all the moisture in the system.
Re: A/C advice needed [Re: smos001] #1664115
08/27/14 04:51 AM
08/27/14 04:51 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm no expert, but I think there is a special flush solvent you use? Then you need to drain and refill the compressor oil with the correct amount of oil. Then replace the drier.
Here is a link I found:
http://www.teamec.be/cms_files/Flushing%20and%20Cleaning(EN).pdf
Re: A/C advice needed [Re: 451Mopar] #1664116
08/27/14 04:37 PM
08/27/14 04:37 PM
louisiana
louisiana
Thanks for the replies and as usual this site is full of good info.
Re: A/C advice needed [Re: sixty9bee] #1664117
08/27/14 06:20 PM
08/27/14 06:20 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
When I converted mine to 134a using a Bouchillon kit, he told me to clean it with brake clean. That is what I did. In retrospect I should have flushed it. I now have a flush tank ($50) and a quart of flushing solvent is around $10. A quart should be enough to clean the evap.
