Re: A/C advice needed
[Re: smos001]
#1664115
08/27/14 04:51 AM
08/27/14 04:51 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
While we are on the subject, I am putting a perfect fit Classic AC in my 70 challenger also. The evaporator in the dash is the only component that is not being replaced. The AC has been out of the car for several years. What do I have to do to flush the evaporator to use it with these new components? The evaporator has been open to the air for many years. Thanks
I'm no expert, but I think there is a special flush solvent you use? Then you need to drain and refill the compressor oil with the correct amount of oil. Then replace the drier.
Here is a link I found: http://www.teamec.be/cms_files/Flushing%20and%20Cleaning(EN).pdf
[Re: sixty9bee]
#1664117
08/27/14 06:20 PM
08/27/14 06:20 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
When I converted mine to 134a using a Bouchillon kit, he told me to clean it with brake clean. That is what I did. In retrospect I should have flushed it. I now have a flush tank ($50) and a quart of flushing solvent is around $10. A quart should be enough to clean the evap.
