Using external balanced Torque Conv with forged crank?
#1663695
08/25/14 11:41 PM
08/25/14 11:41 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all, I've been researching this and think I know the answer, but just want to get confirmation from the experts. I'm currently working on reviving a long-dormant project '66 Coronet. When I pulled the motor, I noticed it had an externally-balanced torque convertor, meant to be used with a cast crankshaft (notice the two weights on the convertor): The 383 I have is not the original motor; I'm told it's from a '66 Chrysler 300. According to the PO, the Coronet had a seized 400 in it when he bought it (400's had cast cranks, which explains the torque convertor). The PO found the Chrysler 383 in a salvage yard, and dropped it in place just prior to selling the car to me (that is, he never ran this motor in this car). I know that 383's had forged crankshafts until 1971. This block has a casting date of 3/22/65, and it appears to have a forged crankshaft: Here's are some pics of the damper that's on it: From what I've read, this torque convertor cannot be used in its present configuration with this engine, correct? However, I should be able to carefully remove the two weights, and make it suitable for use with this engine. Am I understanding this correctly? Has anyone here had success doing this? As always, all suggestions are appreciated - thanks. Roger
Re: Using external balanced Torque Conv with forged crank?
[Re: Fab64]
#1663696
08/25/14 11:57 PM
08/25/14 11:57 PM
Posts: 4,848 Memphis
HemiRick
Memphis
You are correct you need to remove the weights or get a converter w/o them.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: buildanother]
#1663698
08/26/14 02:29 AM
08/26/14 02:29 AM
Fab64
So Cal, USA
Wow, you gonna scrape that greasy dirty buildup out of that pulley?
Yeah, I plan to clean it up a bit before putting it back in. Heck, that junk would probably throw the balance off by itself - LOL!!
Thanks, guys. I will proceed with the weight-ectomy.
[Re: Fab64]
#1663699
08/26/14 02:46 PM
08/26/14 02:46 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
if the tranny is the original 1966 you may have a problem using the converter for very long, Mopar changed the size and spline count on the pump shafts on all the 727 in either 1966 or 1967 I had a freind who bought and used a 1967 and later race converter in his 1968 GTX that he had bought from a transmision(SP?) shop owner who had changed parts, the front pump and shafts in the tranny. He had drove it for quite a while before it stripped the splines out of the converter sprague My point is for you to make sure the converter and tranny have the same size and spline counts in them
[Re: Fab64]
#1663700
08/26/14 03:21 PM
08/26/14 03:21 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
that seems to be a non HiPo convertor ( due the drain plug )
why not get a new convertor ? MP units are unexpensive... if they are still available of course.
I got couple of years ago, one on its box barelly used in $75 ( 175K ), but 166K will be really nice for an street B body
[Re: NachoRT74]
#1663701
08/26/14 03:27 PM
08/26/14 03:27 PM
NachoRT74
Valencia, España
forget it, it seems MaMopar discontinued these, and just SB 145K are available at this moment now
however googling P4876878AB ( 727 non lock up 166K unit ) some appear
[Re: Cab_Burge]
#1663702
08/26/14 03:52 PM
08/26/14 03:52 PM
Fab64
So Cal, USA
Thanks for the tip, Cab. I will check the sizes before I do anything.
And, Nacho, my current plan is to sell this car, so I'm just trying to get it running at the lowest possible cost right now. Thanks!
[Re: Fab64]
#1663703
08/26/14 05:54 PM
08/26/14 05:54 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since the 727 never used a weighted converter prior to '70 you can be sure the trans has the later input shaft.
[Re: jlatessa]
#1663707
08/27/14 08:21 PM
08/27/14 08:21 PM
Fab64
So Cal, USA
I found the numbers on the transmission - the first set (2538334) indicates this is a '66 Coronet transmission, but the date doesn't look correct (2539 = July 10, 1968):
A pic without the torque convertor:
The smaller input shaft has 24 splines; the larger has 27 splines. I can't verify the sizes, but these spline counts match those in the torque convertor. Does this tell me anything? Does anyone happen to know the spline numbers for the early vs. later input shafts? Or does it even matter? As long as these match, am I good to go (after removing the weights)?
Some pics of the back side of the torque convertor:
As always, opinions welcomed.
[Re: Fab64]
#1663708
08/27/14 08:48 PM
08/27/14 08:48 PM
John_Kunkel
Rio Linda, CA
A build date later than the model year indicates a unit that was built as a parts room replacement part.
[Re: GODSCOUNTRY340]
#1663709
08/27/14 10:00 PM
08/27/14 10:00 PM
Posts: 6,224 JERSEY
RJS
JERSEY
John, did the '69 440 Six Barrel engine use a weighted convertor or was the six pack harmonic balancer enough?
69 440 6 pack motors had passenger car rods and a regular balancer hence a non weighted convertor. Ron
