Lowering the rear..... #1663423
08/25/14 11:43 AM
08/25/14 11:43 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
What's the fastest and easiest way to lower the rear 3 inches?
I've got two sets of van lower control arms to do the front.....
Moparlee
Re: Lowering the rear..... [Re: Robbins] #1663424
08/25/14 12:44 PM
08/25/14 12:44 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
2"with the Chevy lowering shackles. Flip the front leaf spring hangers for another 2" I believe.
Re: Lowering the rear..... [Re: 76dodgeboy] #1663425
08/25/14 02:09 PM
08/25/14 02:09 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Moparlee
Re: Lowering the rear..... [Re: Robbins] #1663426
08/25/14 02:10 PM
08/25/14 02:10 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
This for my 2wd RC....what year of Cheby do I order for? Is there a nice thread on this that I can check out some pictures?
Moparlee
Re: Lowering the rear..... [Re: Robbins] #1663427
08/25/14 11:50 PM
08/25/14 11:50 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
On this page you'll see the Chebby shackles we used on our D100 and the issues involved. May or may not be an issue for you on your RC - depending on bushing sizes:
https://board.moparts.org/ubbthreads/show...e=1&fpart=3
Re: Lowering the rear..... [Re: 70Duster440] #1663428
08/26/14 08:31 PM
08/26/14 08:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
89-98. Bout $40 at auto zone or advance auto. May be in stock even. Mine were
Re: Lowering the rear..... [Re: 76dodgeboy] #1663429
08/26/14 11:02 PM
08/26/14 11:02 PM
Ontario, Canada
84Stepside Offline
Happy Birthday 84Stepside  Offline
Ontario, Canada
i used chevy shackles, and then got my leaf springs rearched to fix my dodge lean, and get it sitting lower. Between the chevy shackles, and getting my springs reworked, the truck rides great, and sits level.
Re: Lowering the rear..... [Re: Robbins] #1663430
08/27/14 01:36 AM
08/27/14 01:36 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
On the rear shackles, the later Chevy ones will get you metric size holes, I have a set and decided not to use them for that reason.
I had my leaf springs de-arched instead.
I think, however, that the earlier, early '70s GM stuff used the american, sized standard bolt sizes, same as Dodge.
But, I didn't buy any just to look at the holes ...
Only guessing, but probably '70 - 72? would do the job, and also thinking the '73-87, same same.
Either of these are only going to get you about 2" though.
It takes gasoline to interest me.
Re: Lowering the rear..... [Re: VL21] #1663431
08/27/14 04:04 PM
08/27/14 04:04 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thanks everybody for the help.
Moparlee
