99 ram gas 5.9 superchips tuner feedback #1663286
08/24/14 11:41 PM
08/24/14 11:41 PM
ky.
K
kenworth_goose Offline OP
K
ky.
I'm thinking about buying a superchips tuner for my 99 ram with a 5.9 gas engine and would like some feedback before I make a purchase. I've read only good things and wonder if you really get those kind of results. They are claiming something like 49 hp and 59 ft. lbs torque. Can I expect those results as well. I just bought the Hughe's engine's lower intake plate and have solved all of my drivability issues with the exception of having enough power. All of the pinging, oil consumption, hi idle etc. is gone. I was using 2-3 quarts every 4-500 miles and now I don't use a single drop of oil. Just needing some feedback.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: kenworth_goose] #1663287
08/25/14 12:14 AM
08/25/14 12:14 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
My experience is cut those figures in half if everything else is stock.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: stumpy] #1663288
08/25/14 12:36 PM
08/25/14 12:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
superchip? do you mean the entire box? I bought a MP box for my 95 5.2 Dakota. It worked great, picked every bit of the 38hp advertised. Only down side is you MUST run at least 91 or it will ping. Even w/ 93 at the track mine would rattle. It loved 104.
Coming soon!!!!
Re: 99 ram gas 5.9 superchips tuner feedback [Re: Mr.Yuck] #1663289
08/25/14 01:26 PM
08/25/14 01:26 PM
Grand Prairie,Texas
Grand Prairie,Texas
He's talking about a handheld tuner made by superchips. http://superchips.com/
Re: 99 ram gas 5.9 superchips tuner feedback [Re: stumpy] #1663290
09/14/14 09:48 AM
09/14/14 09:48 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
just say no to superchips.
you want SCT, which you can get custom tuned to your truck, with your mods, not a one size fits all "close" tune.
want to add a cam that idles with 8" of vacuum? no problem. boost? no problem. build up a 408? go for it! just a stock motor? same answer.
**Photobucket sucks**
Re: 99 ram gas 5.9 superchips tuner feedback [Re: 70Cuda383] #1663291
09/14/14 09:52 AM
09/14/14 09:52 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Re: 99 ram gas 5.9 superchips tuner feedback [Re: 70Cuda383] #1663292
09/14/14 01:09 PM
09/14/14 01:09 PM
ky.
K
K
ky.
I'm leaning towards the superchips tuner. I will never need a custom tune. My truck is a 3/4 ton 4x4 and will never need a custom tune. I've been messing with it to get the best mileage and performance before any programmer would be used. I can get over 24 mpg on the highway while running at 55 with the cruise set. And it's a 360. I've installed the plenum plate from Hughes, full tune up, new upstream o2, cleaned out the cat. I can also average over 20 in the city. My only future plans will be a flowmaster exhaust, and I'll do the crank sensor modification. After those I'll do the superchips programmer.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: kenworth_goose] #1663293
09/14/14 01:57 PM
09/14/14 01:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
99 3/4 ton 4x4 24 mpg.....Now that's funny.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: NITROUSN] #1663294
09/14/14 03:32 PM
09/14/14 03:32 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
my 98 1500 360 2wd barely gets 16mpg at the best & only mods it has are the Hughes airgap intake manifold & true duel exhaust & 3.90 gear
Re: 99 ram gas 5.9 superchips tuner feedback [Re: 98RAM1500] #1663295
09/14/14 06:02 PM
09/14/14 06:02 PM
ky.
K
K
ky.
I thought some of you naysayers would say that. I have a picture to prove it. And I also calculate when I fill up also. The picture isn't clear but it says 23.6 and it climbed to 24.1. That was after driving 25 miles on the interstate @ 55 with the cruise on. I consistently saw 18+ before the 02 and convertor cleaning. Say whatever you want, I drive like I have some sense, take off very easy and run 55 with the cruise on. If I drive stupid I can consistently get 12-14. I've repeated this time and time again, and I'm enjoying my extra money saved from not having a heavy right foot!
Re: 99 ram gas 5.9 superchips tuner feedback [Re: kenworth_goose] #1663296
09/14/14 07:47 PM
09/14/14 07:47 PM
N
NITROUSN Offline
NITROUSN  Offline
N
For a minute I thought it was April fools day. If you lived closer I would make a bet and we would go for a ride.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: NITROUSN] #1663297
09/14/14 10:16 PM
09/14/14 10:16 PM
ky.
K
K
ky.
As soon as I get to where I can drive again after my surgery I'll post a video and prove it. I don't believe it myself.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: kenworth_goose] #1663298
09/14/14 10:59 PM
09/14/14 10:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Flat ground fill tank to the brim, drive 100 miles and refill. Hand calculate. Diesels don't get what you are getting. I sold and drove those trucks for a living. I know what they get.
On a side note with your tuning magic you should go into business as being able to achieve a 100 percent increase in fuel mileage will make you a rich man.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: NITROUSN] #1663299
09/14/14 11:18 PM
09/14/14 11:18 PM
ND
dodgedon Offline
dodgedon  Offline
ND
my 99 V10 gets 21.9 Average..... ON METRIC
10 on US. MPG
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 99 ram gas 5.9 superchips tuner feedback [Re: dodgedon] #1663300
09/15/14 01:24 AM
09/15/14 01:24 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I'm gonna call bs on the 24 mpg too. Hand calculate your mileage and I would be impressed if you got half of what the overhead lie-O-meter says. One of those trucks couldn't get 24 mpg loaded on a trailer being hauled by something else.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 99 ram gas 5.9 superchips tuner feedback [Re: 71yelladustr] #1663301
09/15/14 01:49 AM
09/15/14 01:49 AM
ND
dodgedon Offline
dodgedon  Offline
ND
The picture is very hard to read but if you push that US/M buttom on the left now what does it say? I think it says ECO L/100KM under your number.... And that would make sense.
67 Charger 383 auto
Re: 99 ram gas 5.9 superchips tuner feedback [Re: dodgedon] #1663302
09/15/14 05:43 PM
09/15/14 05:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think it could be possible driving 55 on level ground with the cruise set and 3.55s but it is going to drop off hard as you speed up or encounter hills or speed up and down with traffic... of course you got to figure out how much your time is worth to know if your saving anything (probably not). On a 3 hour trip it will cost you 45 minutes VS driving 70-75 mph. Is that worth it to save a gallon or two of fuel?
In my experience with the overhead meters they are typically around %5 + or - of reality with a couple way outside that.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: HotRodDave] #1663303
09/16/14 10:28 PM
09/16/14 10:28 PM
ky.
K
K
ky.
its on us, I did the metric thing at first. it said it was in the 30's and I knew something wasn't right. I can barley type because of my shoulder. when I hit a hill it drops a few tenths that's all.
Re: 99 ram gas 5.9 superchips tuner feedback [Re: NITROUSN] #1663304
09/17/14 12:55 AM
09/17/14 12:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
... probably won't let you ride along. It won't get the mpg!
Re: 99 ram gas 5.9 superchips tuner feedback [Re: J_BODY] #1663305
09/17/14 01:33 PM
09/17/14 01:33 PM
ky.
K
K
ky.
come on over, you can even drive! cause I'm not allowed for 10 days.
