1964 electric window motor repair #1663278
08/24/14 10:06 PM
08/24/14 10:06 PM
Loveland CO
Jimbo Offline OP
Jimbo  Offline OP
Loveland CO
is there ANYONE out there that repairs or has parts for these motors? The ones I have are in bad shape and need repaired or replaced. they are in a 64 sport fury.
Re: 1964 electric window motor repair [Re: Jimbo] #1663279
08/25/14 12:37 AM
08/25/14 12:37 AM
Andrewh Offline
Andrewh  Offline
the motors are supposed to be the same up to the late 80's.
the plug is different, but they should bolt up and work.
any electrical rebuild shop should be able to rebuild them, but the replacments are cheaper.
becareful replacing them though.
the arms are under spring tension and could hurt you. you need to pin the arm in a vice so it cannot unspring when you remove the motor.
Re: 1964 electric window motor repair [Re: Andrewh] #1663280
08/25/14 07:54 AM
08/25/14 07:54 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The motors pretty much interchange.I used some from a %th Ave.On the arms I can attest to the springs.Had one pop and almost broke my hand.It needed stitches and couldnt move 2 fingers for over a week.Rocky
Chrysler Firepower
Re: 1964 electric window motor repair [Re: therocks] #1663281
08/25/14 02:11 PM
08/25/14 02:11 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If this isn't a 100 point Pebble Beach trailer queen, the safest, easiest way to change them out is to drill a hole over each of the 3 bolts on the inside of the doors so you can get a 1/4 drive socket on them.
This does 2 things. It keeps the regulator clock spring captured so it can't cut off your arm and if you ever need to replace one again, it's a 5 minute job.
Dorman Part No. 742-300 left and 301 for right side if you want to go new.
Kevin
