383 valve spring specs. #1663103
08/24/14 05:12 PM
08/24/14 05:12 PM
midwest - USA
69/70 Plymies Offline OP
midwest - USA
Can anyone tell me the ratings of these valve springs? Need to know if they are interchangeable: Mopar#P3690933 vs. Comp#926-16
Ref. 1970 Plymouth 383HP
Re: 383 valve spring specs. [Re: 69/70 Plymies] #1663104
08/25/14 01:04 PM
08/25/14 01:04 PM
dogdays Offline
dogdays  Offline
COMP Cams#249-926-16
Single Outer Valve Springs
•Rate: 415 lbs
•1.062'' ID, 1.476'' OD
•Seat Load: 109 lbs at 1.800''
•Open Load: 317 lbs at 1.300''
•Coil Bind Height: 1.140''
•With Damper
MP springs - there aren't any published specs that I can find. MP doesn't think we're smart enough to use specifications.
I'd pick the other springs.
R.
Re: 383 valve spring specs. [Re: 69/70 Plymies] #1663105
08/25/14 11:54 PM
08/25/14 11:54 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
933s are good for .510 lift !
Re: 383 valve spring specs. [Re: dogdays] #1663106
08/26/14 12:28 AM
08/26/14 12:28 AM
midwest - USA
midwest - USA
Hey,Dogdays,your statement made my day..hard laugh. Isn't it the truth. Us Mopar motorheads can hold our own, anywhere! Details is what blows other cars doors off! Thanks for the details.
Re: 383 valve spring specs. [Re: 69/70 Plymies] #1663107
08/26/14 11:45 PM
08/26/14 11:45 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
It is more spring then required.
MLR426
