518 install, how do I plumb the hydraulics / fittings?
#1662673
08/23/14 05:19 PM
08/23/14 05:19 PM
Posts: 4,748 Florida
BDW
Putting a 518 in my Challenger and need to remotely locate the OD pressure switch. Where do I find the plumbing in this pic? Need the low profile right angle adapter and the coupling/lines? Can I buy pre-fabed lines or is this easy to cobble together? There's at least 50-60lbs of pressure or more. Thx
Re: 518 install, how do I plumb the hydraulics / fittings?
[Re: stumpy]
#1662675
08/23/14 05:45 PM
08/23/14 05:45 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
The governor pressure tap is 1/8NPT. The line in that picture is mild steel tube with the flared ends, looks like 5/16 with the green coating. Needs to be able to handle 100 PSI, as the pressure is close to 1 PSI per MPH. Should be able to pretty much use anything that will transfer that pressure.
I have found many brass fittings on Amazon lately.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
