Help with Carb Adjustment 1969 426 hemi
#166226
12/11/08 07:45 PM
12/11/08 07:45 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
final stages of getting the hemi put back together.
primary carb, I think it is a Carter AFB 4621S.
When adjusting the idle screw, can't get it adjusted between dying at idle and 1500 rpms.
with only a 1/4 turn of the screw it goes from dying to 1500 rpms at idle. What could be wrong?
can't find any vacuum leaks,everything else looks good.
thanks! 3X
68 Charger, 383 HP console auto, spring green, stock restoration
