Gasser Project #1662128
08/21/14 10:44 PM
08/21/14 10:44 PM
WI
W
wannadrag Offline OP
W
WI
Sorta in the beginning stages.I would like to run a BB mopar but nobody makes a gasser style header and not really liking the looks of a A body fenderwell header.Could say a 55-57 bb chevy fenderwell header be cut and mated to bb mopar flanges?I got the idea from a HAMB thread a fews years back and just got rolling on it a few weeks ago,41 Willys front mated to a 50 F1 ford cab.
Re: Gasser Project [Re: wannadrag] #1662129
08/21/14 11:24 PM
08/21/14 11:24 PM
moparx Offline
moparx  Offline
that reminds me of mopar ron's race truck. a dodge cab mated to a willys nose. ther is a thread somewhere on here about it. looks like you got a neat project !
Re: Gasser Project [Re: moparx] #1662130
08/23/14 12:36 PM
08/23/14 12:36 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
if I remember correctly bb chevy exhaust is spaced like this
0 0 0 0
bigblock mopar-
0 00 0
BUT anything could be made to fit, it just depends on how much time and skills you have.
Re: Gasser Project [Re: 65rbdodge] #1662131
08/23/14 04:28 PM
08/23/14 04:28 PM
WI
W
W
WI
0 0 0 0
bigblock mopar-
0 00 0
Yup you are correct,looks like maybe a sb chevy port layout is closer
Re: Gasser Project [Re: wannadrag] #1662132
08/23/14 06:58 PM
08/23/14 06:58 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
I agree I think a set of large tube SB chevy headers would work out best, a 440 flange and just move the front and rear tubes outward,
here is my dodge cab with the willys nose
some day I will get back to building it
need to finish some other projects first.
Re: Gasser Project [Re: wannadrag] #1662133
09/01/14 12:40 PM
09/01/14 12:40 PM
usa
W
whomper1 Offline
whomper1  Offline
W
usa
there are drag race supplier companies that sell kits with flanges and a bunch of tubes bent at different angles
a fried did that on a big block colt he was building and it worked out
Re: Gasser Project [Re: whomper1] #1662134
09/07/14 11:36 PM
09/07/14 11:36 PM
WI
W
W
WI
Some progress,got the box cut down,Rearend mounted,frontend up 3".
Re: Gasser Project [Re: wannadrag] #1662135
12/09/14 11:29 PM
12/09/14 11:29 PM
WI
W
W
WI
Little more done
Re: Gasser Project [Re: wannadrag] #1662136
12/09/14 11:31 PM
12/09/14 11:31 PM
WI
W
W
WI
Re: Gasser Project [Re: wannadrag] #1662137
12/09/14 11:34 PM
12/09/14 11:34 PM
WI
W
W
WI
Re: Gasser Project [Re: wannadrag] #1662138
01/26/15 01:14 AM
01/26/15 01:14 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sweet toy.
I like what you did with the square tubes on that floor.
Hope you don't mind if I steal that idea.
I have mechanical Aptitude.
I can screw up anything.
Re: Gasser Project [Re: bboogieart] #1662139
01/27/15 12:14 AM
01/27/15 12:14 AM
WI
W
W
WI
Some assembly
Re: Gasser Project [Re: wannadrag] #1662140
01/27/15 12:16 AM
01/27/15 12:16 AM
WI
W
W
WI
Re: Gasser Project [Re: wannadrag] #1662141
01/27/15 03:35 PM
01/27/15 03:35 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Re: Gasser Project [Re: bboogieart] #1662142
02/08/15 11:40 PM
02/08/15 11:40 PM
WI
W
W
WI
Some progress
Re: Gasser Project [Re: wannadrag] #1662143
02/11/15 01:56 PM
02/11/15 01:56 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I like it!
How does the cowl width on the Ford cab compare to the Willys hood? I like Ron's truck too and this seems like a fairly economical way to get that Willys style without having to find a $$ Willys first.
What did you end up doing for headers?
Kevin
Re: Gasser Project [Re: Twostick] #1662144
02/11/15 10:26 PM
02/11/15 10:26 PM
WI
W
W
WI
I like it!
Kevin
Cowl was close,i did have to round out the top corners so the hood would fit and also the half moon shape behind the hood had to be filled as the F1 hood and hinges are in that area. I also had the trim the back edge of the hood to match the curve of the F1 cowl. In order to get the front lined up with the wheel openings the cab was moved back roughly 12" and the lower cowl cut sorta moon shaped so the fenders fit into it similar to a willys. Steering column is pretty long on a F1 so I just laid it back and drilled some new mounting holes. The frame also needs to be cut flush with the front crossmember and the box needs to be cut the same amount the cab was moved back.
For headers I used sb chevy patriot fenderwell type,the port layout is close to a bb mopar. I cut the flanges off and had to spread the tubes a little to fit the mopar flanges.The raw headers are $189 and about $40 on the flanges so you have a pretty inexpensive set when done.
These builds I always have the steering done,headers done before mounting the engine so it doesn't get so involved trying to fit the headers.
Jay
Re: Gasser Project [Re: wannadrag] #1662145
02/12/15 02:56 PM
02/12/15 02:56 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I absolutely love your truck and can't wait to see it done! Would have never guessed a Willys nose would fit relatively easily on a Ford F1 cab.
Re: Gasser Project [Re: wannadrag] #1662146
02/12/15 05:35 PM
02/12/15 05:35 PM
Mopar Ron Offline
Mopar Ron  Offline
what are your plans for the willys hood body line, on to the door?
Re: Gasser Project [Re: Mopar Ron] #1662147
02/12/15 09:39 PM
02/12/15 09:39 PM
WI
W
W
WI
Thinking of matching it at the front of the cowl and fading it away to the rear of it
