Still have 69B Body Charging prolm #1662021
08/21/14 06:56 PM
08/21/14 06:56 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I replaced the reman NAPA alternator and it did not fix the problem. The one I took off which only had less that 120 miles, which worked fine till then.. when I pulled it off the rear bearing looked blue like the rotor shorted out.. I was only getting 12.64 volt off the large lead.. Put the new one on, still not charging,, getting 12.64 volts off the power wire on the back of the alt... I installed a electronic voltage regulator when I restored the car,, all new wiring harness.. I'm thinking it fried the new regulator also when it shorted out.. But I still should get 14.2 volts out of the back of the alternator with the new alt. even with a bad regulator right? Amp gage works goods,, it shows discharge when lights are turned on.. Thanks for your help..
Re: Still have 69B Body Charging prolm [Re: JohnH] #1662022
08/21/14 07:04 PM
08/21/14 07:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't think you will be getting full charge voltage from the alternator with a bad regulator because it doesn't sense any demand. I'm may be wrong. Be sure the regulator case has a good paint free ground between it and the body.
Re: Still have 69B Body Charging prolm [Re: JohnH] #1662023
08/21/14 08:11 PM
08/21/14 08:11 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I think Stumpy is right about the regulator but why not take the alt back to NAPA and have them test it? most auto parts stores do that free of charge (pun intended )
Re: Still have 69B Body Charging prolm [Re: mikemee1331] #1662024
08/21/14 10:21 PM
08/21/14 10:21 PM
Andrewh Offline
Andrewh  Offline
yeah, it wouldn't be the first bad part out of the box.
I always make them test alt's and starters before I walk out of the store.
Re: Still have 69B Body Charging prolm [Re: Andrewh] #1662025
08/21/14 10:34 PM
08/21/14 10:34 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I guess I'll take it to Advance to have it checked.. Even tho I got it at NAPA,, they don't check them at the store I bought it.. On the box REBUILT IN MEXICO...
Re: Still have 69B Body Charging prolm [Re: JohnH] #1662026
08/22/14 02:05 AM
08/22/14 02:05 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
does it change when you speed up the engine?
Old style Mopar alternators didnt put out much power at idle speed.
you can also start the engine and pull the battery terminal off, if it dies the alternator is dead wiring bad or regulator, if it stays running you may be OK.
Re: Still have 69B Body Charging prolm [Re: sthemi] #1662027
08/22/14 11:20 AM
08/22/14 11:20 AM
WV
JohnH Offline OP
JohnH  Offline OP
WV
It won't run when you disconnect the batt..
Re: Still have 69B Body Charging prolm [Re: JohnH] #1662028
08/22/14 12:01 PM
08/22/14 12:01 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Electronic ignition or points?
how did you do the conversion to electronic regulator ?
Re: Still have 69B Body Charging prolm [Re: JohnRR] #1662029
08/23/14 11:19 PM
08/23/14 11:19 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Points system... I ordered the electronic VR from YO.. When I installed the new wiring harness started the engine, everything worked just great.. The rear bearing on the other alternator was blue like the rotor shorted out.. replaced the alt. still no charge.. took it to Advance Auto, the alt was putting out 14.5 volts.. I reinstalled the alt. and put a new voltage regulator on and every thing works great.. I'm thinking the VR fried when the other alt. shorted out.. I reinstalled the old type VR.. I'm ready cruise.. Thanks for everyone's input.. By the way the alt will not show volts when the VR is inop.. I was wrong,, I thought it did.. Thank and keep the oily side down..
