BRAKE ISSUE / PART 2 ? #1661945
08/21/14 01:44 PM
08/21/14 01:44 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Some time back, I repurchases a low mileage 78 Magnum (long story).
Previous owner had issues w/the calipers locking up, so figuring that the calipers were aged and had the original phenolic? pistons, they'd need changed. So... I changed the calipers, hydraulic lines, and pads. Road testing and they keep not releasing, last trip out and it did so again. I did have a hard time bleeding these for some reason. Now, that they're bled they're sticking or hanging up. I re-inspected the calipers and appear to be free moving.
Would the master cylinder cause this or should I remove/replace the proportioning valve? Oh, the rears work just fine BTW.
Thoughts
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: BRAKE ISSUE / PART 2 ? [Re: Magnumguy] #1661946
08/21/14 02:15 PM
08/21/14 02:15 PM
booster pushrod round nub clearance to bottom of MC rear piston "thimble" correct (~.020" or so). EDIT you could unbolt the MC and pull it forward a bit & insert some spacers between MC and booster to space it forward then bolt it back snug & that'll quickly tell you if the pushrod was preloading the piston. Not sure how far to space it, I'd wing it & see how it goes
Re: BRAKE ISSUE / PART 2 ? [Re: RapidRobert] #1661947
08/23/14 12:38 AM
08/23/14 12:38 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Bingo! If you open a bleeder screw and the drag goes away instantly, that's confirmation.
Rick
Re: BRAKE ISSUE / PART 2 ? [Re: Rick_Ehrenberg] #1661948
08/23/14 11:01 PM
08/23/14 11:01 PM
Rick has you covered even better. With the wheels off the ground, crack a bleeder & you'll know in 5 seconds if it is a (psi) problem (if the wheels go free(er). discs always have some drag some calipers more than others
Re: BRAKE ISSUE / PART 2 ? [Re: Magnumguy] #1661949
08/23/14 11:07 PM
08/23/14 11:07 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Does it have the correct master?
Re: BRAKE ISSUE / PART 2 ? [Re: nomore65BelvJim] #1661950
08/23/14 11:57 PM
08/23/14 11:57 PM
S.E.Ohio
S.E.Ohio
It's original one, yes.
Now, can that piston or rod be adjusted? Or do like one poster said put in spacers?
Re: BRAKE ISSUE / PART 2 ? [Re: Magnumguy] #1661951
08/24/14 04:19 AM
08/24/14 04:19 AM
I'm betting thats the problem.
They are inexpensive ($15-$30) and its 36+ years old, I'd replace it.
Re: BRAKE ISSUE / PART 2 ? [Re: Magnumguy] #1661952
08/24/14 10:27 AM
08/24/14 10:27 AM
moparx Offline
moparx  Offline
bill, that nub on the booster rod is threaded. no spacers are needed on the master to booster connection.
Re: BRAKE ISSUE / PART 2 ? [Re: Magnumguy] #1661953
08/24/14 12:01 PM
08/24/14 12:01 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Install one of these.
It's Swifty! Swifty, you toad sucker!
Re: BRAKE ISSUE / PART 2 ? [Re: zrxkawboy] #1661954
08/24/14 12:14 PM
08/24/14 12:14 PM
If PB, the round threaded nub on the end of the booster pushrod yes it is adjustable. Spacing the MC forward was only a quick check to see if the threaded nub is too long & is in fact preloading the piston & is causing the problem. If it is then seperate the MC & thread in (shorten) the nub. If MB the adjustable manual brake pushrod in the pic is for restoring proper brake pedal height, the MC piston return springs in a MB app will always return the pedal past the preload problem area
Re: BRAKE ISSUE / PART 2 ? [Re: RapidRobert] #1661955
08/25/14 01:22 PM
08/25/14 01:22 PM
S.E.Ohio
S.E.Ohio
Thanks y'all!
I bought a new MC ($26 @ NAPA), didn't get to install it yet. Life does get in the way.
HOpe to get it in tonight and we'll see what's up
Re: BRAKE ISSUE / PART 2 ? [Re: Magnumguy] #1661956
08/26/14 12:10 AM
08/26/14 12:10 AM
S.E.Ohio
S.E.Ohio
OK, it appears the new m/c cured the problem, it was leaking out the back, and while in there, backed the plunger back some. Just in case.
Brakes are soft now, not sure how well I got the m/c bled, but they're not holding on at all now.
Case closed (I hope)
