BRAKE ISSUE / PART 2 ?
#1661945
08/21/14 01:44 PM
08/21/14 01:44 PM
Posts: 10,647 S.E.Ohio
Magnumguy
S.E.Ohio
Some time back, I repurchases a low mileage 78 Magnum (long story).
Previous owner had issues w/the calipers locking up, so figuring that the calipers were aged and had the original phenolic? pistons, they'd need changed. So... I changed the calipers, hydraulic lines, and pads. Road testing and they keep not releasing, last trip out and it did so again. I did have a hard time bleeding these for some reason. Now, that they're bled they're sticking or hanging up. I re-inspected the calipers and appear to be free moving.
Would the master cylinder cause this or should I remove/replace the proportioning valve? Oh, the rears work just fine BTW.
Thoughts
Re: BRAKE ISSUE / PART 2 ?
[Re: Magnumguy]
#1661946
08/21/14 02:15 PM
08/21/14 02:15 PM
RapidRobert
booster pushrod round nub clearance to bottom of MC rear piston "thimble" correct (~.020" or so). EDIT you could unbolt the MC and pull it forward a bit & insert some spacers between MC and booster to space it forward then bolt it back snug & that'll quickly tell you if the pushrod was preloading the piston. Not sure how far to space it, I'd wing it & see how it goes
[Re: RapidRobert]
#1661947
08/23/14 12:38 AM
08/23/14 12:38 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Bingo! If you open a bleeder screw and the drag goes away instantly, that's confirmation.
Rick
[Re: Rick_Ehrenberg]
#1661948
08/23/14 11:01 PM
08/23/14 11:01 PM
RapidRobert
Rick has you covered even better. With the wheels off the ground, crack a bleeder & you'll know in 5 seconds if it is a (psi) problem (if the wheels go free(er). discs always have some drag some calipers more than others
[Re: nomore65BelvJim]
#1661950
08/23/14 11:57 PM
08/23/14 11:57 PM
Magnumguy
S.E.Ohio
Does it have the correct master?
It's original one, yes.
Now, can that piston or rod be adjusted? Or do like one poster said put in spacers?
[Re: Magnumguy]
#1661952
08/24/14 10:27 AM
08/24/14 10:27 AM
Posts: 19,591 north of coder
moparx
bill, that nub on the booster rod is threaded. no spacers are needed on the master to booster connection.
[Re: zrxkawboy]
#1661954
08/24/14 12:14 PM
08/24/14 12:14 PM
RapidRobert
If PB, the round threaded nub on the end of the booster pushrod yes it is adjustable. Spacing the MC forward was only a quick check to see if the threaded nub is too long & is in fact preloading the piston & is causing the problem. If it is then seperate the MC & thread in (shorten) the nub. If MB the adjustable manual brake pushrod in the pic is for restoring proper brake pedal height, the MC piston return springs in a MB app will always return the pedal past the preload problem area
[Re: RapidRobert]
#1661955
08/25/14 01:22 PM
08/25/14 01:22 PM
Magnumguy
S.E.Ohio
Thanks y'all! I bought a new MC ($26 @ NAPA), didn't get to install it yet. Life does get in the way. HOpe to get it in tonight and we'll see what's up
