Indy RB Tunnel Ram plenum spacer #1661846
08/21/14 10:25 AM
08/21/14 10:25 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
How thick a plenum spacer have you run on one of the INDY RB 4150 style tunnel rams? The plenum volume seems awfully small!
Just curious as to what others have tried with what results.
Alan Jones
Re: Indy RB Tunnel Ram plenum spacer [Re: LA360] #1661847
08/21/14 04:36 PM
08/21/14 04:36 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
3/8 to 1/2 inch,1/2" is the popular one,larger home made if you have the clearence at the hood scoop,it should be a minimum of 3/8 between the vent tubes and scoop.
