My new ricks stainless tank work of art #1661810
08/21/14 04:12 AM
08/21/14 04:12 AM
sandwich IL
sublimehemi Offline OP
sandwich IL
Had this custom built....very trick
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: My new ricks stainless tank work of art [Re: sublimehemi] #1661811
08/21/14 11:46 AM
08/21/14 11:46 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Where's mine?
You weren't just thinking of yourself, were you?
- Stu Harmon
Re: My new ricks stainless tank work of art [Re: sublimehemi] #1661812
08/21/14 12:06 PM
08/21/14 12:06 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What is the application?
It looks like internal fuel pump is set in lowered cavity to feed from a sump?
Looks pretty and $.
Re: My new ricks stainless tank work of art [Re: sublimehemi] #1661813
08/21/14 12:29 PM
08/21/14 12:29 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
Trick indeed, and gorgeous! A work of art for sure!
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: My new ricks stainless tank work of art [Re: sublimehemi] #1661814
08/21/14 02:49 PM
08/21/14 02:49 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
We need details...
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: My new ricks stainless tank work of art [Re: AlexP] #1661815
08/21/14 08:08 PM
08/21/14 08:08 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
curious as to what your price was for this...
Re: My new ricks stainless tank work of art [Re: AlexP] #1661816
08/21/14 08:24 PM
08/21/14 08:24 PM
sandwich IL
sandwich IL
Ok for my 70 charger with stock fill tube a special order a1000 stealth drop in pump...the pump screen is mounted on pump body not on a tube extension like what's shown on aeromotive website...my part number on pump is 11126 and is not shown on aeromotive website the reason for this is because the one with the extension would take up to much depth making my sump to big and i will post a pic of the hot rod city garage tank in attachment...i was going to get a tank built by him but he raised his prices by 100% and was being a Jerk to me quoting me high prices and I'm glad I did not get a tank built by him for many reasons....One my sump would have been too deep and it's flush with back of Tank causing issuies with hotchkis rear sway...next reason is he does not provide a channel at top of Tank for the frame section in floorboard as it would not sit right and be rocking....next reason is that guy will not make it with stock fill tube inlet...you have ro cut your original and use a piece of hose and clamps...and he uses the aeromotive pump with screen attachment and tube extension....plus ricks rounds the body of the tanks...and i got the best sending unit in the buiz... and mounted on the correct side where my wire comes out of floor is....im really happy with the new tank fit perfect and I purchased new double lip mopar seal for fill tube....
Re: My new ricks stainless tank work of art [Re: dangina] #1661817
08/21/14 08:38 PM
08/21/14 08:38 PM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
Will they build an extended capacity tank? I would love an extra 4-5 gallons if I could get it to fit
Re: My new ricks stainless tank work of art [Re: FuryBoy] #1661818
08/21/14 09:59 PM
08/21/14 09:59 PM
IN
ahy Offline
ahy  Offline
IN
Ricks will any size you desire with the provision that with non stock dimensions, fit is the responsibility of the buyer. I had an E body EFI tank made with +1" depth for an extra gallon or so. Stainless straps are longer to compensate and it fits great. I considered making it wider also but fit was tight and I didn't have time for measurement and mock up.
Re: My new ricks stainless tank work of art [Re: ahy] #1661819
08/22/14 12:42 AM
08/22/14 12:42 AM
mass
K
kotacars Offline
kotacars  Offline
K
mass
What sending unit did they use? Also what was the price
Re: My new ricks stainless tank work of art [Re: ahy] #1661820
08/22/14 01:03 AM
08/22/14 01:03 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I just put one of these in my car too, but I went with the gen V camaro SS fuel pump module (built in pressure regulator so no return line needed). I really like it so far.
Re: My new ricks stainless tank work of art [Re: kotacars] #1661821
08/22/14 03:03 AM
08/22/14 03:03 AM
sandwich IL
sandwich IL
Well I don't know what brand it is but it's called a tube style called the vaporworx..if you use the search engine at jegs by typing ricks tanks you will see it along with the cheaper versions with the floats that ricks tanks sells...the cost is 140 at jegs...
Re: My new ricks stainless tank work of art [Re: kotacars] #1661822
08/23/14 10:43 AM
08/23/14 10:43 AM
IN
ahy Offline
ahy  Offline
IN
The sending unit is aftermarket and bolts in from the top. Calibration on mine gives a useful but pessimistic fuel gauge with a stock rebuilt OE gauge cluster. The +1" depth probably does not help with fuel gauge accuracy. Mine could use some tweaking of the pickup arm. From memory, cost was ~$1,500 with a Bosch EFI pump good for around 7-800 HP.
Re: My new ricks stainless tank work of art [Re: ahy] #1661823
08/24/14 09:08 AM
08/24/14 09:08 AM
moparx Offline
moparx  Offline
are you saying you can calibrate or tweek one of those tube style sending units ? if so, how do you go about doing that ?
Re: My new ricks stainless tank work of art [Re: ahy] #1661824
08/24/14 02:42 PM
08/24/14 02:42 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
the tube sending units are from isspro
vaporworx is the remote pickups feeding the pump - check out vaporworx.com
Re: My new ricks stainless tank work of art [Re: ntstlgl1970] #1661825
08/24/14 02:46 PM
08/24/14 02:46 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
pic
Re: My new ricks stainless tank work of art [Re: ntstlgl1970] #1661826
08/24/14 03:02 PM
08/24/14 03:02 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had a tube style sending unit from isspro that I tried in my aluminum drop tank in the Torana...was'nt too happy with it, seemed to read off sometimes and would hang up sort of from time to time it seemed. I went with a float arm style instead and been happy with it.
(My tank is about 120 liters...nearly 32 gallons)
Re: My new ricks stainless tank work of art [Re: ntstlgl1970] #1661827
08/24/14 11:09 PM
08/24/14 11:09 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That's an internal baffle on the left in the last pic, and its a foamless system?
Re: My new ricks stainless tank work of art [Re: jcc] #1661828
08/26/14 02:02 AM
08/26/14 02:02 AM
dangina Offline
dangina  Offline
sick setup!
Re: My new ricks stainless tank work of art [Re: jcc] #1661829
08/27/14 07:50 PM
08/27/14 07:50 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Yes, baffles left and right with the venturi siphon pickups. the vaporworx website has some good info on how the pickups work
