Re: School me on American Teardrop Racing Mags
[Re: BarryBum]
#166145
12/11/08 05:54 PM
12/11/08 05:54 PM
Posts: 15,487 Florida
scratchnfotraction
well..IMO those look a little rusty which is not going to come off you could have them glass beaded and paint them up some I rember seeing some that where painted up back in the day,they didnt look bad at a distance they look to be uni lug also, maybe clean and powder coat them have seen some craigers SS rims painted? powder coated maybe ? the same coler as the car,low rider car at that 75 not bad for 4 rims I guess ...but is the rust worth you getting a set after all these yrs? do them even make them any more? they remind me of stock 78 z-28 rims sorta
[Re: Part_Stalker]
#166148
12/11/08 07:14 PM
12/11/08 07:14 PM
Posts: 20,559 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Too rusty. Maybe you could have them blasted and powdercoat them silver so they look more like an all aluminum wheel? My brother picked up a set of four 15x8.5's in the GM car bolt pattern for $200.00. They are the early ones that are one piece aluminum. They show up on ebay occasionally if you keep an eye out. I saw a set of larger ones (17"?) on a 70 Z-28 and they looked better than the 15" do. Normally I don't like the bigger diameter wheels, but those looked great.
[Re: SPWC]
#166150
12/11/08 08:05 PM
12/11/08 08:05 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
There are a few different versions of the 200S (aka Daisy, aka Coke Bottle).
The originals are one piece cast aluminum with a machined lip, much like the Torq Thrust D. I believe these were introduced around 1969. I had a set of these, and it took several years of hunting to find a matched set of 15x7 and 15x8.5. 14-inchers are far more common.
There were also some 16-inch bead lock produced for slicks.
In the early-mid 70's they came out with the modular two piece wheel [edit]called the CP 200 [edit] (as you have) utilizing the chrome steel rim. Most all of these you'll come across are rusted beyond repair. As with most chromed wheels of the era, they didn't weather very well.
In the last 5-10 years they reintroduced them as a two piece polished aluminum design. You can get them in 15 and 17 inch sizes.
As with the Torq Thrust, there were a few copies of the original style made by other companies. I've never seen any knock-off of the later styles.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#166151
12/11/08 11:42 PM
12/11/08 11:42 PM
Posts: 9,836 MI, usa
dvw
MI, usa
The wheels are American 200-S.They are currently repoped in the 2 piece design. Aluminum center,steel outer,chrome plated. The manufacturing process is like a Cragar S/S. The originals are one piece aluminum. rough cast center with apolished outter. The 7",8 1/2" are both pretty common. The 15x10 are tougher to find. The 15x4 are nearly impossible to find. It took me 3 years to find a set. I currenly have 4 15x7,6 15x8 1/2,2 15x10, and 3 15x4. I would love to find another 15x4. I'm also looking for 15x12 which I have never seen but I believe were produced. A buddy of mine had a pair of the 16" ones, he may still. Doug
[Re: dvw]
#166152
12/11/08 11:43 PM
12/11/08 11:43 PM
dvw
MI, usa
[Re: dvw]
#166153
12/11/08 11:45 PM
12/11/08 11:45 PM
dvw
MI, usa
The wifes car. I actually bought this set new in 1978. I restored them 5 years ago. Blasted the center,sanded and polished the outer rim. Didn't take to long,about 3 hours each. I painted the spokes,very low maintance. Polish the outtrs once or twice a year. The centers just wash off. The new style center caps fit the old wheels also. Doug
[Re: TiMopar]
#166157
12/12/08 12:03 PM
12/12/08 12:03 PM
I love the true 1 piece aluminum 200S and will get another set soon I hope. The two piece style I'm not so crazy about.
Sheldon
