Page 6 of 11 1 2 4 5 6 7 8 10 11
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661410
09/14/14 06:15 PM
09/14/14 06:15 PM
GA
roadrunninMark Offline
GA
Muu, are you using the hydro boost with the 15/16 m/c? What did you get the hydro boost out of?
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: roadrunninMark] #1661411
09/15/14 02:08 AM
09/15/14 02:08 AM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Right now, no hydroboost. I've got a 1 1/32" bore MC on there now. If the pedal is too stiff, I'll probably go down to a 15/16" MC and go from there.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661412
09/18/14 10:03 PM
09/18/14 10:03 PM
SoCal
SoCal
Was doing some work on the Dart today. Got some brake clips in to hold the hard lines. Unfortunately I messed up and set myself back another week. Before I bought my brakes I had bought "restored" 73+ A body Drum brake spindles thinking they'd work with the Doctor Diff kit. Nope, I was stupid and didn't look over the website carefully. Now I've got to order some Repro disc brake spindles tonight. Anyways, after closer inspection, the threads on the spindles I have were a little banged up and had parts of it had been grinded. I've also been stressing too much over which wheels I should get.
This is going to be difficult. School starts a week from today. I've got to get this car on the road before Oct 25 (Fall Fling).
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661413
09/18/14 11:36 PM
09/18/14 11:36 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
you can still basically put the entire front end together minus the spindles and tensioning the torsion bars. Once the spindles arrive, it will be cake. All that would be left is installing the brake kit and welding on the sway bar tabs in the front. You could have the rear complete as well before then.
Just keep plugging away at it.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: goldduster318] #1661414
09/19/14 01:34 AM
09/19/14 01:34 AM
SoCal
SoCal
I just ordered the spindle should be here in 3 business days, so I'm assuming around Wed next week.
We already hand tightened the pitman and idler arm to the steering linkages and K frame. Tomorrow we're going to install the LCA and strut rods (maybe even the torsion bars). One problem we had with the LCA pins is that the pins kept on spinning in the bushing (already greased) when we tried tightening it. We figured that the pin wasn't completely seated in the bushing and are going to try to seat them tomorrow. The rear of the car is already completely complete.
We'd like to do the front brakes off the car and on the spindles as it's easier to work with. Besides that, I need wheels and tires (been stressing me out lately for whatever reason), I need a new driveshaft cut/made, and subframe connectors welded in (our new brake lines are going to mount to them). Sway bars can hold off for a little while as they shouldn't effect the alignment after installation.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661415
09/19/14 08:05 PM
09/19/14 08:05 PM
Lake Orion, MI
Lake Orion, MI
The combination of the Knuckles, hubs, bearings, rotors, calipers, and lower ball joint together is one big heavy mess, probably in the 60-80 lb range. Personally, I'd mount the knuckles up first and assemble from there, especially considering the LBJ has to be assembled first and the taper points up.
For the LCA pins, you'd probably want to use a block of wood and try to bash them in a little bit to get it to stick on the taper until you can tighten.
The whole wheel thing is complicated because of the A-body rear axle...the front track is probably still a significant difference from the rear. After reading your other topics, looks like the Darts have less room in both the front and rear than a Duster. I'm looking to measure with my wheel-rite and probably go with 275-35-18 on 18x9 +35 offset (6.4 backspace) wheels, and maybe a small spacer with my factory 11.75 fronts.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: goldduster318] #1661416
09/19/14 08:33 PM
09/19/14 08:33 PM
SoCal
SoCal
Thinking about it, the hub and rotor assembly was already pretty heavy.
We're working on it right now. Hitting the LCA with a mallet trying to get the pins to stick. I may pm Dan real quick.
I'm still on the hunt. The offset thing is definitely a PIA. I'm thinking 18 x 9.5" for now with a 245/40/18.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661417
09/19/14 08:49 PM
09/19/14 08:49 PM
SoCal
SoCal
Through some research, apparently vice grips are required for the pins.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661418
09/19/14 09:11 PM
09/19/14 09:11 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Just shot a reply to your PM. If you'd like, you can share it here. I forgot to copy it before I sent it.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: Dan@Hotchkis] #1661419
09/19/14 09:14 PM
09/19/14 09:14 PM
SoCal
SoCal
Dan's reply to the pins...
You'll want to install the Torsion bars and then bang them in with a large punch from behind. Make sure the pin is fully seated. Then tighten the best you can (but not all the way). Load the suspension (weight of the vehicle) then fully tighten the pin. It can get fun, best of luck.
Too bad my friend just left. He had to go home to attend to his dogs (no one's home) but I think we're just going to leave this for next week when the spindles come in. Brakes shouldn't take too long so I'm going to need wheels asap.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661420
09/19/14 11:21 PM
09/19/14 11:21 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Ive never had the pin issue, I have FF pins and just hit them with my impact, zip zoop done.
Mopar to the bone!!!
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661421
09/22/14 09:33 PM
09/22/14 09:33 PM
SoCal
SoCal
Got some more work out today. I removed the driveshaft (making a big ATF mess ) and my friend and I cut the ends, measured what we need to, and the ends should be shipped to member Old Goat to have a new driveshaft made.
Also, we brought out a punch and a BFH for the pins and started hammering the back side so that we'd can start tightening them down. This method did work out great. Only problem we had was at a point the nut bottomed out on the threads before the pin fully seated in the K-frame so we added the oem washers underneath the Hotchkis washers. We still have full thread engagement on the nut (about 3-4 threads showing).
I've been juggling back and forth between Cass and I regarding tracking numbers. He had to drop ship them from the supplier so they may get here later in the week. Hopefully brakes will probably be done by Saturday. I'll do some quick measurements and I'll order my wheels.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661422
12/19/14 11:09 PM
12/19/14 11:09 PM
SoCal
SoCal
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661423
12/19/14 11:32 PM
12/19/14 11:32 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Looks good! Don't shoot your car
We have all been (or still are) there and know the frustration
when you finally get everything together though the feeling is awesome!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: RylisPro] #1661424
12/20/14 12:13 AM
12/20/14 12:13 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I like how Hotchkis positioned the upper ball joint, at droop it isn't pretty but still OK, but at a lower than stock ride height I bet it is in the sweet spot.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661425
12/20/14 12:35 AM
12/20/14 12:35 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You sure that's on the right side?
Might be an optical illusion but it looks like negative caster to me.
Don't be the exception.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: Supercuda] #1661426
12/20/14 12:44 AM
12/20/14 12:44 AM
Watch your clocking on the strut heim as well. You should tighten everything down at or about ride height and make sure that all the heims are in a neutral position.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: MuuMuu101] #1661427
12/20/14 01:01 AM
12/20/14 01:01 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I wanna see this with rear mounted high performance brake calipers. I've never seen an A-body Hotchkis Upper Control arm with anything but a stock caliper and rotor 11.75" or 10.75"
BTW you cant run rear mounted 11.75" stock pin caliper setup with the Hotchkis Upper Control Arm.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: autoxcuda] #1661428
12/20/14 01:20 AM
12/20/14 01:20 AM
NY NY
3
340duster340 Offline
NY NY
its hard to tell from the pics, but is the bolt head for the lower ball joint facing in or out? it should be facing out. with the nut on the inner ball joint side.
either way, nice progress. its definitely a hurdle point so you'll back back on the road soon.
Re: Hotchkis TVS, Brakes, and Rear End Install [Re: 340duster340] #1661429
12/20/14 05:44 AM
12/20/14 05:44 AM
SoCal
SoCal
You saw it right. I thought that's how they were on my old brake package but it's an easy swap. Nothing is torqued down. Anyways, next week I'll call over my friend and we'll finish brakes and maybe suspension. Wheels won't ship till the 30th apparently.
