Correct color: 69-68 B-body steering column
#1661271
08/20/14 01:10 AM
08/20/14 01:10 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Hello, I am restoring the steering columns for my 2 B-bodies, one with a black interior the other saddle. Original finish is gone on both so I am trying to figure them out. It looks like the actual shaft and coupler should be natural metal but not sure about the housing part which protrudes into the engine bay - flat black? Should the complete steering wheel shaft housing be flat black including the ignition switch collars?
For the car with the saddle interior, should the shaft housing be painted saddle?
Thanks, Carl
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
Re: Correct color: 69-68 B-body steering column
[Re: 69rrgrabber]
#1661272
08/20/14 05:15 AM
08/20/14 05:15 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
For 69 Plymouth and Dodge, an interior color chart is in the service manuals, page 23-154 or 23-108, suede finish colors. The 68 Plymouth service manual does not have color charts. Don't know about the 68 Dodge manual. Download service manuals here for free, except 68 Dodge: http://www.mymopar.com/index.php?pid=109
[Re: Stanton]
#1661282
08/22/14 03:11 AM
08/22/14 03:11 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Thank you so much for the pictures and advice,I really appreciate it.
Thanks, Carl
1970 Cuda 440
[Re: 69rrgrabber]
#1661283
08/22/14 03:16 AM
08/22/14 03:16 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Bill, I saw the restored ash tray on your face book, did you find new plastic grommets for the tab or are those original? I'm looking for some too.
1970 Cuda 440
[Re: 69rrgrabber]
#1661284
08/22/14 09:19 AM
08/22/14 09:19 AM
Posts: 21,471 It's a dry heat
gtx6970
It's a dry heat
Originals, plating process doesn't effect them. I dis-assembled the ash tray then lightly glassbeaded them ,then off to the plater. Rivets came from Rivetsonline.com
