Cast or Moly rings for 366NP pistons - '70 383 rebuild? #1661079
08/19/14 03:20 PM
08/19/14 03:20 PM
midwest - USA
69/70 Plymies Offline OP
midwest - USA
What rings should I be installing for stock rebuild b-body 383HP engine. This car is street, daily driver and occasionally hammer down. Want longevity.
Re: Cast or Moly rings for 366NP pistons - '70 383 rebuild? [Re: 69/70 Plymies] #1661080
08/19/14 04:56 PM
08/19/14 04:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Have you already bought the pistons ? Is this a turbo application because you are going to have a low compression ratio , 8.0 ... probably less ..., with those pistons ?
Moly would be better than cast .
Re: Cast or Moly rings for 366NP pistons - '70 383 rebuild? [Re: JohnRR] #1661081
08/19/14 05:16 PM
08/19/14 05:16 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Moly.
Re: Cast or Moly rings for 366NP pistons - '70 383 rebuild? [Re: topside] #1661082
08/19/14 08:39 PM
08/19/14 08:39 PM
(1) Moly (file fit/plasma moly) (2) final hone with 320 grit dingle berry hone (3) read "breakin secrets" at www.mototuneusa.com
Re: Cast or Moly rings for 366NP pistons - '70 383 rebuild? [Re: JohnRR] #1661083
08/23/14 04:18 PM
08/23/14 04:18 PM
midwest - USA
midwest - USA
JohnRR, I will be using the existing pistons. The machinist told me the compression ratio should be +-9.35:1.
