Does this reproduction AAR hood look correct?
#166096
12/11/08 12:06 PM
12/11/08 12:06 PM
Posts: 1,128 Tulsa, OK
73cudaproject
Tulsa, OK
After longer than I care to admit I recently went to the truck terminal and picked up a reproduction AAR hood. To me it looks great except for what I think is a rather strange looking gap in the fiber glass. The hole inside the scoop area on each side looks rather strange to me. I think it is best described with the following picture: Is that large gap correct? Looks like it will let air/water in between the top and bottom. I have no idea what this area is suppose to look like.
Re: Does this reproduction AAR hood look correct?
[Re: 1_WILD_RT]
#166100
12/11/08 01:19 PM
12/11/08 01:19 PM
73cudaproject
Tulsa, OK
If anything thats a cleaner hole then a factory AAR hood..
Interesting. I did no realize the factory hoods also had these fairly large holes on the sides. I had considered filling in the gaps.
[Re: RylisPro]
#166103
12/11/08 01:51 PM
12/11/08 01:51 PM
73cudaproject
Tulsa, OK
Yep that is what I am talking about! I got such a good deal I was thinking maybe I was sold a hood with some type of defect. These cutouts looked sort of out of place and I have been somewhat concerned ever since I picked up the hood. Thanks for posting the detailed pictures. I feel better!
[Re: 19704406]
#166106
12/11/08 04:20 PM
12/11/08 04:20 PM
heres a trick i learned.
the correct way to open an AAR hood: Put your hand into the scoop PALM SIDE DOWN and grab the bottom part of the hood NOT THE TOP. and pull towards you. the hood will open.
if you grab the top of the scoop and lift, it will crack eventually
