Torque flite not solid shift in 3rd.
#1660969
08/19/14 01:39 AM
08/19/14 01:39 AM
Posts: 6 Princeton, Indiana
Nuggetcharger
Princeton, Indiana
I have a 62 push button I rebuilt. has a 67 front pump and clutch change has shift kit and 3000 converter. Problem shifts 1-2 solid 2-3 over revs under light power. What is the problem driving crazy. Checked governor and went thru. valve body. Any answers or guesses.
62 Polara 500,440Ci., 3000 stall, 355 gear and Pearl Blue white stripe
Re: Torque flite not solid shift in 3rd.
[Re: Nuggetcharger]
#1660970
08/19/14 01:52 AM
08/19/14 01:52 AM
Posts: 43,180 Bend,OR USA
Cab_Burge
I would look at the shifter cable adjustment in the tranny, the early 727 with the cable shifters are real sensitive to that. I race several of them for a lot of years, I ended up taking the tranny pans off when adjusting the shifter cables, I would remove the C clip on the end of the male cable end that slides into the rooster comb arm and adjust the big wheel on the exterior cable until the end, pin, would slide, drop in with no forcing into the rooster comb arm hole in nuetral, 1st, 2nd and 3rd gear. If my memory serves me correct there is only one or two holes in the big wheel that will give you that adjustment, make sure and tighten the little retaining bolt into the case that holds the adjustment wheel still after each adjustment before checking the results of that adjustment I've seen the same symptons(SP?) on the later 727 with after market cable floor shifters, the pin has to drop into the hole in the tran shifter arm with no forcing on all the forward gears and neutral What is happening is the tranny valve body is not routing all the fluid to each gear properly, you can burn the tranny up with it not adjusted properly
[Re: Cab_Burge]
#1660971
08/19/14 01:01 PM
08/19/14 01:01 PM
Nuggetcharger
Princeton, Indiana
Thanks I'll give that a try, you mean take the cable off under dash at push buttons?
[Re: Nuggetcharger]
#1660973
08/19/14 03:41 PM
08/19/14 03:41 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I doubt the problem is related to shift cable adjustment but, if in doubt, push the Neutral button, remove the NSS (you'll lose some fluid if the car is level) and check the position of the internal metal tab (might need a mirror)....it should be dead center in the hole in Neutral.
RPM flareup on the 2-3 shift is usually an internal problem like a loose band/loose clutch clearances or pressure leakage but TP linkage adjustment might exacerbate the problem.
[Re: John_Kunkel]
#1660974
08/19/14 08:39 PM
08/19/14 08:39 PM
Posts: 1,443 Maryland
Dads426
Maryland
I had that problem in my Challenger (street car). 2-3 shift got later and later. Turned out the groove in the high gear piston was machined wrong causing it to leak. This was common on '80s transmissions from Chrysler. Takes a few years for it to wear enough to leak. If your trans has later parts this could be the cause. An air test should narrow it down.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
