06 pt 2.4 non-turbo 5 spd, CHK ENG AND IN LIMP HOME MODE.
When at normal operating temp wont rev over 3200.
Cold, runs to red line until warm, every start, w/o resetting code.
1. Purchased 1 month back with broken t-belt.
2. Continues to show 0340 Cam/Crank sensor (replaced both OEM)
3. Checked harness for broken wire at pins.
4. Compression cold is 160-180.
5. Was showing low oil light, pulled sensor, installed mechanical gauge, 80 cold, when warm..35 idle, 75 over 1500, installed new sensor, now no light.
6. Have not replaced magnet on cam, (runs too well cold)
7. Crank and Camshafts are on the marks.
my experience;
Nissan tech, Chrysler tech, Hunter Tech and Training rep, electronics tech, 7 yrs building and racing water cooled (928's).
