Re: Clutch is slipping
[Re: 68CoronetRT]
#1660565
08/18/14 02:25 PM
08/18/14 02:25 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
If the flywheel is new no need to resurface.Remind me of guys that surfaced new drums and rotors.They should be ready to install after cleaning.I also agree with a Center Force clutch.I dont like Ram.As long as it is all clean and adjusted right it should light up the rears.What gears are in it?A lot of clutches need a seat in period.Rocky
Chrysler Firepower
[Re: 68LAR]
#1660566
08/18/14 02:56 PM
08/18/14 02:56 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Any suggestions?
Yep, CFDF. Don't like RAM stuff in muscle cars. Just my
I agree! Same exact experience I had with my hemi challenger. Installed a Centerforce DF & no slip even on a few 4K rpm launches. My bro also toasted his Ram clutch with his 490-500 hp 440 Charger. Now nas a dual disc McCloud behind the new Hemi.
[Re: Triggerfish]
#1660567
08/18/14 08:33 PM
08/18/14 08:33 PM
dogdays
Clutches do need to be broken in.
The Number One reason a clutch won't grab is the throwout bearing holding it a little bit open.
I have a feeling that if God Almighty designed and built a clutch package, somebody on this board would say he didn't like it!
R.
CORRECTION: Yes, the original post said the flywheel was new.I went back and had to read it three times to notice it. Maybe that's because it was right in front of my nose?
[Re: dogdays]
#1660568
08/18/14 08:44 PM
08/18/14 08:44 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Clutches don't see horsepower. They see torque. Your engine probably doesn't make more torque than stock, just at a higher rpm. A stock clutch should be able to work with your setup.
Clutch is adjusted wrong.
Did you resurface the flywheel?
R.
You were also having trouble a few weeks ago reinstalling the clutch fork. Is it in all 3 clips? 2 on throwout bearing and 1 pivot?
[Re: pushbutton]
#1660570
08/18/14 10:31 PM
08/18/14 10:31 PM
Posts: 5,163 CT
GTX MATT
CT
Is this a powergrip hd? I have one behind my 500+ hp 440. Admittedly I didn't really let it break in because the engine was fresh too. I had been turned off by Ram a long time ago but someone I knew ran a 10.97 with a single disc ram, so I figured I'd do it. Plus I wanted a B&B. My car had 2.94 gears when I got it back together with M&H J60s. A few clutch dumps went good and spun hard, but it seems now that sometimes it isn't smoking the tires. I've not smelled clutch though, so I'm not sure. Lots going against it, and I knew I was taking a risk, so I'm not complaining. I was basically doing 2nd gear clutch dumps with sticky tires. I'm not sure if I'd just replace it or go to a CFDF. I like a firm pedal/ B&B feel so I went with the Ram.
