Best thermostat out there #1660539
08/18/14 09:59 AM
08/18/14 09:59 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Question, what are ya'lls experience with quality thermostats? I was running the Hemi in the Daytona this weekend and the dang new thermostat didn't open and the car got to 250 real quick... Freaked me out a wee bit. Got her back in the garage with now harm I believe, just some steam out the radiator.... But, I will replace the thermostat, but want to put a good performer in there this time..
Troy
Houston Mopar Connection Club
Re: Best thermostat out there [Re: hemi68charger] #1660540
08/18/14 10:01 AM
08/18/14 10:01 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC I used a super stat from Summit.I believe its a Moroso.Been in at least 15 years and no problems.Rocky
Chrysler Firepower
Re: Best thermostat out there [Re: hemi68charger] #1660541
08/18/14 11:07 AM
08/18/14 11:07 AM
You just run into a bad one. Get another name brand (Stant etc) & work the plunger several times to make sure it is free then suspend it in a pot of water & bring it to just below boiling & confirm that it opens. Best would be to use a candy thermometer to confirm it opens within ~5 deg of it's rated temp. A Moroso racing stat might be a better choice yet. No Robertshaw, when it came out it was touted as a trick piece (not sure what the trick was, maybe it opened further) but my parts man couldn't believe the # of comebacks they had with em
Re: Best thermostat out there [Re: hemi68charger] #1660542
08/18/14 11:41 AM
08/18/14 11:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I run the Milodon 16406 180 degree in most of my toys big and smblk
Summit carries it for about $20
Re: Best thermostat out there [Re: hemi68charger] #1660543
08/18/14 11:47 AM
08/18/14 11:47 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Hey gang..
If I send you the correct O.E.M would that make your day ?
