Front disk brake conversion question
#1660399
08/17/14 10:37 PM
08/17/14 10:37 PM
Posts: 161 Logansport, Indiana
Budman
Logansport, Indiana
Im wanting to buy a front disk brake conversion kit for my 67 Belvedere. Its a street driven Big Block car. Im wanting something lightweight and the best "Bang for the Buck".
All MOPARS & nothig else.
Re: Front disk brake conversion question
[Re: Budman]
#1660400
08/17/14 11:16 PM
08/17/14 11:16 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
contact dr diff on this site or do a search on the web for Dr. Diff. other than that there is a write up in the tech section on what to do and what to get.
[Re: can.al]
#1660409
08/18/14 04:45 PM
08/18/14 04:45 PM
Posts: 543 Indiana, Just Off I-70
BradD
Also check out kits from MBM, Speedway Motors, and Wysco Product.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: BradD]
#1660410
08/18/14 05:20 PM
08/18/14 05:20 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
If low cost is what you are looking for, go with a set of FMJ spindles/rotors/calipers. The haters will be in complaining about the bogus spindle height issue in 3...2...1... Check with 65belvjim. He had a set a couple days ago.
[Re: RobX4406]
#1660411
08/18/14 11:45 PM
08/18/14 11:45 PM
Budman
Logansport, Indiana
WOW Thank you everybody for all the info. Great suggestions and Im taking them all in. Im not looking for the cheapest just good set up. I would like to find a set that not as heavy as the factory stuff. Thanks for all ur suggestions. I will continue my research. All ideas and suggestions are welcome. Thanks again
[Re: Budman]
#1660412
08/19/14 01:43 AM
08/19/14 01:43 AM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
I just did this swap in the spring on my 67 Belvedere. I used the kit from Right Stuff Detailing(lines and all). Simple kit, everything was included. No major bending of lines.
Ok
[Re: Budman]
#1660415
08/19/14 12:28 PM
08/19/14 12:28 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
I bought spindles off a 73 dart...the rest off napa..(bearings,pads,rotors,install kit,etc) and cost just under 400.00
67 R/T...stops.....excellent.....but if you have $$$$$$$ to burn....get a 800 + kit
[Re: dynamite]
#1660417
08/19/14 08:05 PM
08/19/14 08:05 PM
mikemee1331
bethlehem pa
I'm using the whole FMJ disc brake setup..stops straight hard..and cheap!!
all right, i'll bite. what is FMJ disc brakes. I can't find anything!
