Re: Speedometer Error - Rowand Speedometer Co.
[Re: stumpy]
#166006
12/11/08 12:22 PM
12/11/08 12:22 PM
RapidRobert
jack the car up on the drivers side, you'll loose less fluid that way. for a correct selection put a bar of flat stock on top of one of your rear tires & measure the height to ground & you know your new rear gear ratio, with those 2 figures go into the archives & find the correct # of teeth speedometer pinion gear you need & good used ones are for sale in the parts for sale section.
