Big Block Swap Wire Harness ? #165993
12/11/08 04:07 AM
12/11/08 04:07 AM
IN
polaraholic Offline OP
IN
I'm going to put a 440 in my 74 (318) challenger. Will the small block wire harness work? I know the difference with the distributor but is everything else the same. Also could I buy a harness for an earlier challenger that came with a BB or would there be different conections for the earlier cars? Thanks for any help. Steve
Re: Big Block Swap Wire Harness ? [Re: polaraholic] #165994
12/11/08 05:52 AM
12/11/08 05:52 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
It will work just fine, you just need longer wires for the dist and coil and ECU if you mount in a different location.
Re: Big Block Swap Wire Harness ? [Re: DAMOPARS] #165995
12/11/08 06:52 AM
12/11/08 06:52 AM
IN
IN
Thanks, I figured that a new harness would be overkill but if it saved some wiring problems later it would be worth it.
Re: Big Block Swap Wire Harness ? [Re: polaraholic] #165996
12/11/08 12:35 PM
12/11/08 12:35 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I went the other way, I put a big block harness in my 340 car. It was a good harness, and it had the A/C wiring, so I decided to use it. All I had to do was shorten the distributor leads, which were dried out anyway. The alternator leads were dried out too, so I just did both using the same color wire, soldered everything, and re-used the original connectors or ones that matched pretty close. It looks and works great, no problems yet.
