rear axle centerline question, a-body #1659499
08/15/14 11:08 PM
08/15/14 11:08 PM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
Working on 71 dart swinger. I am putting ladder bars in it and was curious of some kind of hard measurement that could help me locate the rear in the factory location. The car has a hacked up spring relocation kit in it that was never finished and basically have nothing trusty to go off of. Or should I just put a tire under it and get myself a comfortable amount of clearance and go with that?
If someone could give me a measurement from the front of the front leaf spring perch, or in other words the back of that crossmember, to the centerline of the axle I think that would get me pretty close. looking to run a 28-10.5 tire.
thanks
Re: rear axle centerline question, a-body [Re: skj283] #1659500
08/16/14 07:42 PM
08/16/14 07:42 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I measured a 71 Duster body with a stock leaf and 8 1/4 rear and I get 21" from the mounting plate that the front leaf spring hanger bolts to to the top middle of the axle tube and I get 21 inches, with the car on jack stands and the suspension hanging down, no shocks. But I'd not go with that - put the tire/rim combo in the car where it gives you the clearance you need and work from that, and work out any changes needed to the drive shaft length, shock mounts, fender trimming, etc. Most Swinger bodies need a bit of trimming on the front edge of the lower qtr for tire clearance when the rear is in the stock location. Some guys resort to adding spacers between the front hanger and the body mount. See the tech pages on BigBlockDart.com for a step by step to show trimming one.
Re: rear axle centerline question, a-body [Re: Sixpak] #1659501
08/16/14 08:16 PM
08/16/14 08:16 PM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
good deal. that will ball park me anyways. I will definitely read that article. Upper shock mounts wont be an issue due to the fact I can put them wherever they need to be and driveshaft hasn't been made yet either. I was thinking about just putting it where I felt I had comfortable tire clearance but the way the wheel wells are, if you move it back then you run into clearance issues on the back side of the tire quick. centered in the well, is tight on the front side. thanks again
Re: rear axle centerline question, a-body [Re: skj283] #1659502
08/17/14 06:21 PM
08/17/14 06:21 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
71 A bodies with 8 3/4 rear had 43" from spring perch to spring perch. Measured on center, with the pinion centered.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: rear axle centerline question, a-body [Re: DemonDust] #1659503
08/18/14 12:30 AM
08/18/14 12:30 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
Darts and Scamps have longer wheel base then Dusters and Demons...fwiw....
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: rear axle centerline question, a-body [Re: cheapstreetdustr] #1659504
08/20/14 01:11 AM
08/20/14 01:11 AM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
dually noted good sir. I'll bring this back to the top and see if anyone else has anything to add. I know that there are several different ways to change wheelbase on cars. I would assume that if they take the same front leaf spring segment length, then the length from the mount/crossmemeber/bulkhead, whatever u wanna call it, to the axle would be the same, but I also know what assumptions are the mother of.
Re: rear axle centerline question, a-body [Re: skj283] #1659505
08/20/14 01:19 AM
08/20/14 01:19 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
When i put ladder bars under my valiant i measured from where the factory perches bolted to the frame back to where i wanted the axle centerline to be in the wheel housing. FWIW, you will probably have to move the axle back a little to fit a 28" tire into a stock wheelhouse as the axle was towards the front of the housing from the factory on Darts. I made 3/8" plates to bolt between the spring perch and the factory mounting location to fit a 28" tall tire under my dart, otherwise the tire would rub the front of the 1/4 panel.
Re: rear axle centerline question, a-body [Re: 340_Dart] #1659506
08/22/14 02:26 PM
08/22/14 02:26 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Late to the party, but I'll offer my thoughts.
If I were replacing the stock suspension and installing a crossmember and ladder bars, the original location of the rear is irrelevant to me. If I need to open up the wheel opening for a larger tire, I would move the rear centerline forward enough so that I only need to move the front half of the opening forward.
If I wanted it in the stock appearing location, I would take everything from under the car, mock the wheel/tire combination in the wheel opening where I wanted it for clearance and apperance and let that determine where the rear goes.
Bottom line is, put the wheel where you want it. Let that determine where the rear goes. Also consider that moving the rear forward some will improve the weight distribution.
In other words,if you consider the entire rear suspension (rear, bars, crossmember) as a unit, it can be mocked up and measured to determine the distance from the axle centerline to the front of the crossmember. Put the wheels (aka. axle centerline) where you want them and measure forward that assembly dimension. That is where the crossmember will meet the stock floor.
Level the car, string line or laser everything, draw it out on the floor and make it straight and square.
All of this is assuming you are eliminating the leaf springs.
Re: rear axle centerline question, a-body [Re: CMcAllister] #1659507
09/26/14 01:26 AM
09/26/14 01:26 AM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
just wanted to let you know the last comment didn't fall on deaf ears. That is basically the way I went. I am lowering the car significantly and found the wheel wells on these things are far from symmetrical. I basically found a happy medium on wheel well clearance, and worked from there. I actually came up with 21 inches as of now for a starting point, but its gonna be tight on the front, and plan on trimming the quarters to gain clearance. This is my first ladder bar install, and I have learned a ton along the way. I also found the front eye mounts are off about 3/8 of an inch from square to the frame, so that already invalidates my 21. Planning to tack all my brackets on the rear, and the front crossmember this weekend and start actually fitting it up as it will be installed. came up with about 1 1/8th yoke offset towards the pass side, on a slant 6 crossmember with engine swap mounts that I picked up along the way. I really enjoy this forum due to the patience with newbies. I due have a experienced chassis guy helping me with my million questions I come up with along the way though, so that helps.
Also car is definitely leveled, and I have plotted everything out on the floor with chalk lines and plumb bobs. I have the block and trans in it to find engine centerlines to find yoke offset before I narrow rear. And going to coilovers, with the upper mount located on the down bars from the roll bar also.
Re: rear axle centerline question, a-body [Re: skj283] #1659508
09/26/14 08:29 PM
09/26/14 08:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A-body springs are 20 inches center bolt to spring eye,brackets are 2 inchs, hole to flat where its attached to frame.
Meant to add 7 1/4 brackets different than 8 1/4-3/4
Re: rear axle centerline question, a-body [Re: cudaman1969] #1659509
10/12/14 01:38 AM
10/12/14 01:38 AM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
here are some pics of my progress so far.
Re: rear axle centerline question, a-body [Re: skj283] #1659510
10/12/14 01:39 AM
10/12/14 01:39 AM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
another
Re: rear axle centerline question, a-body [Re: skj283] #1659511
10/12/14 01:40 AM
10/12/14 01:40 AM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
and another
Re: rear axle centerline question, a-body [Re: skj283] #1659512
10/12/14 01:43 AM
10/12/14 01:43 AM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
last one for now
Re: rear axle centerline question, a-body [Re: skj283] #1659513
10/13/14 10:00 AM
10/13/14 10:00 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
What rear is that?
Re: rear axle centerline question, a-body [Re: 340_Dart] #1659514
10/13/14 01:21 PM
10/13/14 01:21 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
That looks like a ford 8.8
Re: rear axle centerline question, a-body [Re: 340_Dart] #1659515
10/13/14 01:22 PM
10/13/14 01:22 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Looks like a Ford 8.8".
Re: rear axle centerline question, a-body [Re: DoctorDiff] #1659516
10/13/14 03:49 PM
10/13/14 03:49 PM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
busted...lol. I don't have any 8 3/4 stuff so I went this route. can buy a limited slip, disc brake, 31 spline explorer rear for 200 bucks locally with the gear ratio I wanted. my plan was to tell people its a dana, cuz 90 percent of people wouldn't know the difference. figured they would see the cover and say, "must be a dana".
Re: rear axle centerline question, a-body [Re: DoctorDiff] #1659517
10/13/14 03:59 PM
10/13/14 03:59 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
How strong is an 8.8?
Do they have adjusters or shims to set the carrier like the Dana S60? Matt
Re: rear axle centerline question, a-body [Re: MattW] #1659518
10/13/14 04:03 PM
10/13/14 04:03 PM
sedalia, mo
skj283 Offline OP
skj283  Offline OP
sedalia, mo
shims. they are pretty stout. been a lot of them in the 9's. I'm putting 9 inch ends on this so I don't have to run c clip eliminators, and im also gonna run aftermarket axles. I figured the money saved on the brakes, gears and lsd, was well worth it though for now. down the road I may go 8 3/4 or 9 inch. hopefully these ford parts don't get me banned from this forum. lol
