Re: Nice Job!
[Re: 69Cuda340S]
#165891
12/04/12 12:01 AM
12/04/12 12:01 AM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
My new plates showed up over the weekend. I found two sets of 72-74 Iowa plates at my grandparents estate sale. I thought one might be the original set to the car but that wasn't the case. I found the correct numbers on the original title though. I had some repro tags made with the same numbers the car originally had. There are a few differences but overall I like it. The color should really pop against the body color. Iowa allows you to run a year of manufacture plate as long as you keep the state issued tags in the car somewhere. I e-mailed the Iowa DOT about this because I couldn't find anything in writing. They sent me the Iowa code section that says this is legal. I printed it off and will keep it in the car just incase I need it. Original 72-74 Iowa plate on top... ![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/challenger/plate006.jpg)
Re: Nice Job!
[Re: burdar]
#165904
11/08/13 12:15 PM
11/08/13 12:15 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Re: Nice Job!
[Re: burdar]
#165905
11/08/13 12:23 PM
11/08/13 12:23 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
This picture was taken outside my grandmothers house when the car was new. When the car is done, I'd like to take another picture of it in the exact same spot...just 40 years later.
That quote was from the first post on this thread. I finally got to take that picture a few weeks ago. The new owners of the house had a vehicle in the way so I couldn't get the angle just right but it still looks pretty cool.
1973
![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/challenger73002.jpg)
2013
![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/102013007_zpse4efee08.jpg)
Here are a couple other pictures I took that day as well.
![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/102013010_zpscae90bd0.jpg)
![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/102013009_zpsc176f352.jpg)
Re: Nice Job!
[Re: RUNCHARGER]
#165908
11/09/13 09:04 PM
11/09/13 09:04 PM
Re: Nice Job!
[Re: burdar]
#1807717
04/20/15 01:50 PM
04/20/15 01:50 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I decided to bring this thread back from the dead. The last time the Challenger saw the light of day was in October 2013. For the last year and a half it's been under a car cover in a heated shop. After getting it running in the fall of 2012, life got in the way of fixing some bugs and enjoying it. I needed a break, so it was parked. Now it's time to fix the bugs and make it a reliable car. For some reason, storage was not kind to the car. The engine compartment looks awful and some suspension parts have a light coating of surface rust on them. It will need a lot of work. I'll post pictures of the problem areas in the coming weeks. Here it is with the cover off after sleeping for and year and a half. ![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/DSC02691_zps1uujwx3g.jpg) It's dusty but the paint still looks good. ![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/DSC02693_zpsgjvxhur3.jpg) I've had the resto battery sitting in the corner of my garage this entire time with a $10 Harbor Freight "tender" on it. I didn't know if it would still be usable or not. After setting the battery in place the engine cranked over strong. Those "tenders" must do their job. After a couple squirts of gas down the carb, the engine fired right off. While the engine was warming up I installed the battery hold down hardware. After the car was off the jack stands, I spent the next 1/2 hour/45 minutes maneuvering the car out of the shop. I had to squeeze it between the shop door and my cousin's camper. I don't think I had 2" clearance per side. Eventually, I got it out without scratching anything. I don't want to do that again though. Rain showers were supposed to develop in the afternoon so I wanted to get home before the weather got bad. All was good until I got about a 1/2 hour from home when the rain hit. On the bright side, I got a chance to test out the wipers. Also, no water found its way into the interior or into the trunk so that's good. The car is very dirty now though. It will need its first hand washing very shortly. So, while it needs a lot of work, it's safely at home in the garage...with some company. ![](http://i137.photobucket.com/albums/q229/burdar/73%20Challenger/DSC02699_zpse8ctmxkg.jpg)
Re: Nice Job!
[Re: burdar]
#1807833
04/20/15 04:11 PM
04/20/15 04:11 PM
Posts: 933 Chicago
rocksmopar
Chicago
Take her on a roadtrip before you clean her up.
Looking for affordable 72-74 Cuda parts
